Cheap Red LED bias on ecc83/12ax7 - Page 3 - diyAudio
Old 21st October 2012, 06:58 AM   #21
yagoolar's Avatar
Send a message via ICQ to yagoolar Send a message via Skype™ to yagoolar
The idea of using an LED in a cathode is to maintain bias voltage in no dependance to anode current. See LED characteristics.
LED is not a cure for heavy loads on B+. Well designed HV power supply is.
What you can do is to calculate what is ΔVbias in regard to expected ΔB+.
E.g.
B=+302V
Vbias = +2V
Ibias=10mA (one can take anode current change under the load onto account, i.e. ΔB influence on anode current)
ΔB +/- 5% or 30,2V (that is heavy I guess)
Rbias=(302V-2V)/10mA=30kΩ
Now,
30,2V/30kΩ=~1mA or 0,5mA around LED op point. Assume dynamic resistance of a LED is 5Ω
ΔVbias=1mA * 5Ω = 5mV
It is early in PL, so I may have made a mistake somwhere.
Old 21st October 2012, 07:04 AM   #22
dgta is offline dgta  United States
Yagoolar, you didn't understand his question. He wants to avoid the extra 6mA current draw necessary to put more current through the LED than the tube is passing.
Old 21st October 2012, 07:09 AM   #23
yagoolar's Avatar
I was referring to post #19. The question was to use LV PSU and lower value resistor to feed LED. It is not THAT early
My intention was to ask question "what for" if that works well.
Old 16th May 2014, 12:51 PM   #24
Im curious, has anyone since found an LED for 12AX7 LED bias that works well enought at <1ma, so the B+ bias resistor can be avoided?
Old 16th May 2014, 01:26 PM   #25
funk1980's Avatar
There are loads of low power LED's that work fine at around 1mA. Just check e.g. mouser. No idea how linear they are though, but they same pretty linear at the small amount of current variation the ECC83 exhibits.
Old 16th May 2014, 01:31 PM   #26
SY's Avatar
If you have a CCS load in the plate circuit, that pretty much removes the nonlinear Z vs I characteristic of the LED. If not, the B+ resistor is still an easy option.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 16th May 2014, 07:10 PM   #27
I have used low current red LED's for bias operation of ECC83's without having to use the resistor trick for added current.
Old 16th May 2014, 07:31 PM   #28
Its funny, I just last night read a post of yours from a few years ago pointing this out. But I suspect I cant use a CCS plate load in this circuit. Its two sections stacked, bottom tube a mu follower. I was going to try it at some point.
Thanks for these responses, but I was kinda hoping someone would refer to specific part number. I have tried a number of Radio Shack LEDs and so far none of them sound quite right, though the current draw has been reasonably close to the resistor/cap combo I started with. I was hoping somebody made an led that had a linear Z vs I characteristic down to .5ma.
Old 16th May 2014, 07:52 PM   #29
I have a drawer full of LED's but I think these are the ones I found to work good.
Invalid Request
Digikey part #1080-1067-ND
Old 17th May 2014, 06:15 PM   #30
Invalid Request
Thanks! I will check them out.
Preamp with single 12ax7 Ecc83 for stereo? Rodeodave Tubes / Valves 19 20th December 2014 07:43 AM
LED bias for 12ax7 oscillator jjman Tubes / Valves 2 30th June 2009 04:25 PM
Telefunken ECC83 / 12AX7 Used (Old Stock) sorenj07 Swap Meet 2 6th January 2009 04:02 PM
ECC83/12AX7 Tube test query waam68 Tubes / Valves 8 8th November 2007 08:52 PM
Fun circuit with a 12ax7 (ecc83) ebijma Tubes / Valves 7 20th April 2005 08:33 AM
Copyright 1999-2017 diyAudio
