Toroidal (adding a winding)
Old 14th October 2012, 03:51 PM   #11
kevinkr's Avatar
Originally Posted by M Gregg View Post
Regards the windings,
I am thinking of putting two 60V bias windings on the heater Toroid which is 120VA. So they are low current windings.
M. Gregg
Besides the tedium of winding several hundred turns on the existing core there is also the distortion and rectifier harmonics from the filament windings if you are using dc for filament heating.
You might consider a small EI or toroid, were you here in the U.S. I would recommend one of the Antek line, some of them even have electro-static shielding. In terms of dealing with garbage (dust ) from the line you can always use a common/diff mode choke on the primary side.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 14th October 2012, 04:06 PM   #12
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Yes, 60V will require a few turns but if its fairly thin wire that's not a big problem.
As post 8 suggests, and many before it, make yourself a little bobbin that will easily pass through the centre of the toroid (allow for your extra turns). Calculate how long the winding will be and add a good few metres (its sickening if you are a few turns short). You don't need to be exact about spacing the turns around the toroid, close enough is good enough, just try to space them around the core.
HF "hash" passing through the core. Yes, it's true but I've never had any problem with it. A bit of filtering will usually get rid of it. Hell, you've got a toroid in there aleady.
Old 15th October 2012, 01:57 AM   #13
tomchr is online now tomchr  Canada
tomchr's Avatar
Been there, done that: http://www.diyaudio.com/forums/tubes...ml#post2354966
It probably took me about an hour to add two 12 V windings to a toroid. I'm not sure I'd attempt it with a bias winding - definitely not without a bobbin.
~Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 15th October 2012, 04:22 AM   #14
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
M. Gregg
#30 awg magnet wire is ample for bias winding....virtually no grid current flows, only in the voltage deviders...
you can wind say 10 turns to get your actual turns per volt....then you will get your actual turns for 60 volts...when winding, always add 1 turn at the end....
this is very doable....and a lot of fun...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 15th October 2012, 11:30 PM   #15
polyphaze is offline polyphaze  United States
For bias applications, using a simple voltage doubling rectifier circuit will cut the turns count in half. I get -15vdc bias from just 24 turns of #30 wire around the power toroid using this technique. It is close wound and covered with 1 turn of 1/2 in strapping tape.
Old 3rd May 2015, 10:52 PM   #16
cyclecamper is offline cyclecamper  United States
I just added a winding to a tube preamp toroidal power transformer so that I could bump up the B+ by about 50 volts. It was incredibly easy, the trick is definitely all in making a really nice bobbin shuttle. Mine could have been a bit thicker, as I wound the wire around it lengthwise. I used a 26.5 inch long piece of aluminum. I notched the ends for the wire, and then rounded all corners and polished smooth. If I did it again I would use thicker aluminum so that the wire bends around a larger radius at the ends. Perhaps most important, I covered the ends with a shiny smooth liquid rubber that's sold for sealing scratches in vinyl-coated dishwasher racks. It goes on like fingernail polish, but is slightly rubbery, and not high-friction grippy. I should coat all the corners, perhaps the whole thing!
Old 3rd May 2015, 11:34 PM   #17
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
For reasonable efficiency, the weight of copper on the input side should equal the output side
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Toroidal (adding a winding)Hide this!Advertise here!
Dual Winding Toroidal Transformer for Sale AAK Swap Meet 19 25th August 2012 08:47 AM
NICE; Custom 250VA Toroidal Power Transformers; 34vac/7a, plus an Auxiliary Winding dozer Swap Meet 0 19th January 2009 10:10 AM
winding a toroidal mbates14 Power Supplies 16 10th November 2007 04:16 PM
winding a toroidal pp output Dr.Frankenstein Tubes / Valves 21 7th October 2004 08:19 AM
DIY Toroidal Winding Machine audioPT Parts 24 28th March 2004 05:50 PM
