DAC direct out, not enough gain, help me build a driving stage.
Old 12th October 2012, 04:20 PM   #1
50AE is offline 50AE  Bulgaria
Default DAC direct out, not enough gain, help me build a driving stage.
I'm using the AKM4396 DAC direct out without any cap, canceling the +2,5VDC offset with more (-2,5V) bias on the input tube.
The problem is, the direct out unbalanced outputs about 1V maximum and this is not enough. The driver is E180F. The stage gain is about 44. -44 volts aren't enough to drive the output tube 6P45S. I need -75V swing there for full output.
I can get interstage transformers to use the balanced output and hence get 2V, which fixes my problem, but I don't have money now to get high quality ones. This way I will get rid of the offset as well, two birds with one stone.
So I came up with the idea of two stage drivers. The problem is, I want it to be direct coupled, no cap in the way. But doing so, I have to cathode bias the second tube with much voltage to cancel the 1st stage anode voltage.
... so I have to put a cathode capacitor which I don't want to do. I hate cathode bypass.
... I cannot make fixed bias
... I cannot put cathode battery bias (too muc batteries)
... I cannot use cathode resistor only, the gain will be too low, the output impedance will be very high and won't drive the 6P45S
... Or I can buy a higher gain penthode like D3A, but I don't have time and money to do so now.
So what can I do? This is where your help comes.
I could:
1. Use LEDS, if 12V or more ones exist, I could make a chain
2. Use zeners, which I heard that are noisy, except lower voltage ones I heard, from whom I could make a chain
3. Use voltage regulator tube?
http://store.picbg.net/pubpic/EF/D6/...9da052efd6.PNG
Old 12th October 2012, 05:24 PM   #2
211hojbjerg is offline 211hojbjerg  Denmark
Hi high gain,
Gain at 44 looks as triode connected E180F. For more gain and keep at one gain stage, you can connect the E180F as pentode and much more gain.
Ra 10kohm, Ia 15mA, you'll roughly double your gain. If that's too much go for s lower Ra.
Best regards
Karsten
Old 12th October 2012, 06:50 PM   #3
The problem is, it will be have very high output impedance, not sure if will drive the 6P45S well, which has high miller in triode mode.
Also I don't like the look of pentode curves
Old 12th October 2012, 10:56 PM   #4
Output imp will app same as the value as the Ra.
Best
Karsten
Old 13th October 2012, 11:08 PM   #5
Rod Coleman is offline Rod Coleman  United Kingdom
работник
Rod Coleman's Avatar
You can use my shunt-cascode circuit.
With E180F [triode connected] S ~21mA/V
Use load resistor 10K.
Gain ~ 210
No cathode capacitor needed.
Sound easily beats 2-stage driver.
DAC direct out, not enough gain, help me build a driving stage.Hide this!Advertise here!
FS - $150 - Monica 2 DAC (USB + Coax) + SS I/V Gain Stage ianp Swap Meet 0 15th August 2011 11:18 PM
DAC - tube gain stage w/ AC heaters regal Tubes / Valves 5 26th August 2008 01:30 PM
problems when driving a p3a direct from CD player Mark25 Solid State 1 18th November 2006 03:16 PM
Direct driving of GM70 by one ECL86 ??? noyan Tubes / Valves 9 20th February 2005 08:27 AM
Tubes for direct-driving ESL Prune Tubes / Valves 32 14th March 2004 03:59 PM
Copyright ©1999-2017 diyAudio
