cathode bypass in PP output stage? - Page 2 - diyAudio
Old 30th October 2003, 12:30 AM   #11
Tube_Dude's Avatar
You mean to say reliability...(fiablite being a french word).
Sorry!!...thanks for the correction...
Separate cathode resistors can be better still...sonically
That's to subjectif for me...what is good for one people can be the worst for other people...
Knowing that...i never enter in subjectif discussions about sound quality....sorry,one more time...
No argument from me there...saudade!
Saudade ...du chocolat de la Grand Place de Bruxelles!!!
A bientot!
Jorge
Old 30th October 2003, 12:44 AM   #12
Brett's Avatar
Default Re: cathode bypass in PP output stage?
Originally posted by RichJones
Best option:
A) common cathode resistor bypassed
B) common cathode resistor unbypassed
C) choke
D) solid state CCS
This is for 2 6B4G's (Sovtek) running at 398v 60mA each 62v bias through a common 470 ohm resistor.
Thoughts???
CCS. Based not on theorising but having done it with both DHT's (47, GM70, 813) and IHT's (6V6, EL84, EL34, KT88). But this of course limits you to class A.
Rather than repeat all the arguments again here, go to Audio Asylum Tube DIY, and read the last two or three weeks of threads, it's been a hot topic.
As for which one sounds the best, well that's up to you. I've tried them all and know what I prefer.
Old 30th October 2003, 12:58 AM   #13
diyAudio Senior Member
fdegrove's Avatar
He's a dedicated follower of constant current source...give that man his CCS.
Many a road leads to the mountain top.....
Bom dia, Brett.
Kidding agian folk...
Frank
Old 30th October 2003, 01:08 AM   #14
Brett's Avatar
Not always, but there are a number of performance advantages with it here and it's far, far, far from a subtle strain-like-you're-constipated-trying-to-hear-it difference.
Old 30th October 2003, 01:24 AM   #15
fdegrove's Avatar
Sure enough, but, as usual, it takes some intelligence to use the darn things in the appropriate places...
You just can lift a newbie from zero to a hundred...it takes some steps IME.
Sayonara,
Frank
Old 30th October 2003, 04:42 AM   #16
I go with CCS too. but again as mention limits to class A. Another term for CCS is also a current limiter. It would limit the amount of current to its set value. This could help in limiting the extra amount of current flowing thru your tube when something goes wrong.
Old 30th October 2003, 09:23 AM   #17
TG is offline TG  Ukraine
Send a message via ICQ to TG
Best option:
C) choke
D) solid state CCS
E) fixed bias
or separate catode resistors bypassed
398V are plate-to-catode or plate-to-ground?
i.e. 23.88W or 20.16W on plate?
Sovtek 6B4G are 15W max, as far as I remember
Old 30th October 2003, 09:56 AM   #18
fdegrove's Avatar
Maybe someone's building an amp to put under the x-mass tree?
You're quite right that's way too high one way or the other...
Frank
Old 30th October 2003, 04:11 PM   #19
45guy is offline 45guy  United States
Default From Ned's site
6B4-G Sovtek This new monoplate 6B4 looks like a baby 300B! Biases just a hair less than the old US ones, which should make it a bit easier to drive. Looks like just the ticket for people who'd like to experiment with using 6B4 in amps that have 6L6, etc, but don't want to try higher plate voltages with NOS tubes... these have a plate voltage rating of 450V and can be used at a plate dissipation of up to 30W.
I have run them at around 24W with no problems. They sound pretty good at these higher levels too
Tom
Old 30th October 2003, 05:34 PM   #20
Previously: Kuei Yang Wang
Konnichiwa,
Best option:
C) choke
D) solid state CCS
I know plenty of people like the CCS, but it is not always the best solution. Worth trying though. one of the biggest problems with the CCS will be the impedance to ground which may track hum into the circuit. Also, you need a way of balancing the Valves current with ANY form of common cathode ballast. The way I do this is shown in the attached Circuits one for semi-fixed bias (also easily adapted for fixed bias) and the other for self bias.
To measure the current balance I simply make sure that the two halves of the transformer have the same DCR (if not simply add a suitable resistor to balance the DCR) and measure the voltage on the two anodes of the Valves via a pair of 1M "safety" resistors. If there is no voltage difference, then the two valves draw identical current.
I personally would likely tend most towards a choke BTW and seperate, capacitive bypassed cathode resistors is definitly the worst sounding solution....
Sayonara
Cathode Bypass in a PP Output Stage CLS Tubes / Valves 8 15th July 2008 05:32 AM
AD825 output stage:What bypass caps? filholder Digital Source 3 16th April 2005 06:15 PM
bypass output stage in cd 6000 ose Robi Medvesek Digital Source 6 19th July 2004 07:36 AM
Cathode follower Class A output stage? Circlotron Tubes / Valves 14 15th May 2003 11:11 PM
Copyright 1999-2017 diyAudio
