I have a Hickok 539b and my roll chart does not have the test settings for 6BL8/ECF80. If anyone has it on theirs it would be much appreciated if you could post them thanks.
#2 |
6BL8
Fil selectors.....bias, shunt, press . 6.3 EV-2637-1, 1.2 ---- P4 C 3000 (pentode) 6.3 EV-9108-6, 4.8 ---- P4 C 3000 (triode)
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#3 | |
Thank you very much Hollowstate! I just picked up a Scott 299 and needed to test the phase splitters. I am planning on doing a cap job, so I probably will start another thread on that. |
| Help! can't find ef86 on my Hickok 539b roll chart! and need a tube project | famousmockingbird | Tubes / Valves | 4 | 18th February 2011 12:42 AM |
| Can't find 5y3 on Hickok 539b roll chart! | famousmockingbird | Equipment & Tools | 5 | 4th January 2011 10:29 PM |
| Roll Chart for 6DJ8/6922/7308 on Philco 9100 help | thuan98 | Tubes / Valves | 0 | 25th March 2009 06:39 PM |
| ECF80/6BL8 | Tobruk | Tubes / Valves | 4 | 1st May 2007 10:16 PM |
