Old 9th October 2012, 06:31 PM   #1
Default Grommes S35 booster amp output?
I have been tinkering with an old Grommes S35 PA amp from the 60's for a few weeks now. I got it working, nice clean sound and actually sounds very nice with my old les paul, just not much gain. I did wire the two gain stages together in series with a switch, got a nice little gain boost, but not a bunch. The question: There is an RCA output that is labeled "Output tape recdr booster amp.". A friend of mine mentioned that I might get some more gain from the pre-amp stages if I feed this back into the first stage. Is this crazy? Im pretty new to tubes, so thanks in advance for patience and advice!
Old 9th October 2012, 07:23 PM   #2
Yes it is crazy. It will just oscillate. The output is for a tape recorder or
booster amplifier. Use a clean level boost pedal on the input for more
gain, done right it should overdrive the first gain stage into "dirtier".
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
FA: Grommes 61PG Integrated Tube Amp - for repair or restoration joe-electro Swap Meet 0 26th September 2010 12:30 AM
How can I modify this grommes little jewel amp for guitar. DJNUBZ Tubes / Valves 10 2nd April 2010 10:39 PM
Booster amp Marty99 Solid State 1 20th September 2008 01:41 PM
grommes 511a mono tube amp/reciever atticusdog Tubes / Valves 1 9th May 2007 07:24 AM
New Hybrid Output Stage and booster for SE Amp smoking-amp Tubes / Valves 3 20th March 2006 02:24 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
