voltage divider
voltage divider
Old 8th October 2012, 09:14 PM   #1
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Default voltage divider
My preamp has too much gain, I know using a voltage divider at the input can solve, I need to reduce 6 or 12dBs, I think sources have 2V.
Using Z1 & Z2 1R I have an output voltage of 1V = -6dBs attenuation
Using Z1 1R & Z2 0R33 I have an output voltage of 0,5V = -12dBs attenuation
Are my calculations OK?
Old 8th October 2012, 09:27 PM   #2
R.I.P.
Post details of your preamp, a far better solution may be very easy.
An attenuator on the pre-amps output is a very poor solution.
CD has max 2V, most other things less, sometimes all you need
is a CD attenuator built into the lead for the the CD, or similar.
rgds, sreten.
Old 8th October 2012, 09:31 PM   #3
ECC81 mu-follower, gain X60 35,6dBs output impedance 267 ohms
Old 8th October 2012, 09:38 PM   #4
Eli Duttman is offline Eli Duttman  United States
The math is correct. However, you have to allow for the drive capability of the signal source. Modern, digital, sources can drive the IHF "standard" 10 KOhm load. The total of Z1 and Z2 should be at or slightly above 10 KOhms. The load should be 10X (or higher) Z2.
A good construction method for the divider is to place 1/8 W. 1% tolerance metal film resistors inside the RCA plugs, at the preamp end, of the interconnect cables.
Eli D.
Old 8th October 2012, 09:45 PM   #5
I like to have the voltage divider at the RCA inputs because I can left differente attenuation in diffferents input, for example:
1 input 6dB attenuation
2 input 12dB attenuations
3 input without attenuation (to play vinyls)
Old 8th October 2012, 10:45 PM   #6
tomchr is offline tomchr  Canada
tomchr's Avatar
Note that Zload is in parallel with Z2, so if your load impedance is close to Z2, you have to take the loading into account to get your 6 dB of attenuation. As a rule of thumb, if Zload > Z2*10, the loading will be negligible.
In addition, as said by others already, you'll have to ensure that the total impedance of the voltage divider presents a reasonable load impedance to the preamp. With your circuit, you'll probably have to aim for Z1+Z2 > 10 kOhm. Perhaps higher.
A better way to go about this would - in my opinion - be to lower the gain of the preamp. 36 dB is a lot of gain...
~Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 9th October 2012, 04:02 AM   #7
gingertube is offline gingertube  Australia
I agree with Tom that reducing the gain of the preamp would be a good idea, unfortunately I don't see anyway to do that easily without introducing other problems.
The usual method of reducing a triode gain stages gain by deleting the cathode bypass capacitor simply doesn't work for mu followers because the bootstrapped anode load impedance is so high that you have very little signal current swing and so don't develop significant signal voltage (feedback) across the cathode bias resistor, in fact I don't see why the cathode bypass cap is there at all.
FOR DISCUSSION ONLY: You may be able to introduce a feedback loop around the whole stage by adding a divider from after the output coupling cap back to the grid of the lower triode. This would make the lower triodes input grid become a virtual earth mixing point and then different gains for different inputs are easily accommodated by different series input resistors, that is, treat the entire mu-follower as if it were an inverting op-amp, not sure if this would give you something good or an oscillator, maybe someone who has actually tried it could venture an opinion.
Ian
Old 9th October 2012, 09:46 AM   #8
DF96 is online now DF96  England
Why not simple delete the preamp? Or at least bypass it for CD and other high level sources.
Old 9th October 2012, 11:28 AM   #9
Thanks for all advices.
I will try the voltage divider at the input with Z1 6K8 & Z2 3K65, no problem with input impedance of the preamp because is 1Meg, I'll come back with results.
@DF96
That's a good idea I left one stereo input without attenuation to play LPs
voltage dividerHide this!Advertise here!
Voltage divider? fatmarley Solid State 40 18th April 2012 11:10 AM
This novice needs help with Voltage divider jeffreybehr Solid State 11 25th October 2011 09:28 PM
voltage divider in WE91 driver bobluis Tubes / Valves 2 27th August 2010 01:37 AM
Precision Voltage Divider - diy redrabbit Equipment & Tools 3 24th July 2008 04:16 PM
voltage divider+Aikido anawat Tubes / Valves 0 17th October 2007 05:19 PM
