Why can I hear a difference in the sound from my speakers if I put a small value plastic film capacitor in parallel with the electrolytic capacitor in a tube amp power supply?
I understand there are reasons why this might be a good thing to do. The film cap bypasses RF to ground, as the film cap will have a much lower ESR at high frequencies than the electrolytic cap. (What frequencies are we talking about here? 10kHz? 50kHz? 100kHz?) Why is it that the amp sounds brighter when I do this? I've tried this on a number of amps, both speaker and line level. ? In the latest amp, I put a 0.22uF 630V metallized polypropylene cap from +400V plate supply to ground, in parallel with a 47uF 450V Nichicon electrolytic. -- Last edited by rongon; 8th October 2012 at 07:14 PM. Reason: details... |
#2 |
Electrolytics are non-linear, their dielectric is semiconductor. Even if you can't measure or hear difference in frequency response on upper audio frequencies, difference in phase intermodulation is audible.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#3 |
That makes it sound like bypassing an electrolytic cap with a film cap should always be a good thing.
? I was reading in MJ Valve Amplifiers that the film cap should be close to the active device (tube), not physically across the electrolytic cap. That's how I have mine -- at least as close to this as I could. |
#4 |
However they are the last thing you should update.
#5 |
That's exactly right. If anything, I'd expect a reduction in perceived highs when adding the cap if the stage was previously unstable or marginally stable due to insufficient bypassing.
If there's a sucker born every minute, where do the rest of them come from? |
#6 |
Some times it is easier to place the film cap across the last filter cap rather than at the tube, such as when you are using point to point wiring and the anode load resistor is in a terminal strip, or otherwise located away from the tube itself.
#7 | |
If they shunt common voltage source, it is better to solder them closer to the star ground. Leads of electrolytics to the star ground in such case can be longer. If they shunt power of some "previous" stage powered through RC - filter, of course it may be better to solder them to the ground of that stage, to eliminate AC voltage drop on the wire that goes from the ground of this stage to the star ground, closing AC current loop through this cap with short leads. Always think about currents, and you will be happy: knowledge means freedom.
#8 |
Here is a tip i found but the link doesn't work anymore:
In most electronic equipment a rectifier transforms AC to DC. So far so good. A silicon rectifier is a semi-conductor, only letting current go through it when the output voltage is more than 0,5 Volt below the input. At that very moment it switches "ON". Inside a semiconductor there is a capacitance as well. This capacitor, together with the inductance of the wiring, causes a very sharp peak voltage to occur. This peak is too fast to be dampened by the connected (electrolytic) capacitors. The solution is simple: put a resistor between the transformer and the rectifier. In a transistor power amp the value of that resistor may be 0,1 Ohm - 5 Watt. With tube power amps it could be around 1 Ohm and in preamps (transistor and tubes) some 10 Ohms. The result is a more relaxed amplification. It seems as if the sound comes easier out of your loudspeakers and the stereo image is mostly improved. A few dimes will do the job. I now design all my power supplies incorporating this mod. Actually I have just replaced my moscode power supply with my latest design and again I'm amazed at the clarity but this time instead of 5w resistors I used ntc thermistors. In the link below you'll see the old supply in the photo. Mac Myira Moscode Amplifier kits - The Book Worm Last edited by balerit; 8th October 2012 at 08:33 PM. |
#9 | |
Moscode amplifier - The Book Worm |
#10 |
I know tektronix used to do that but they put the resistors Behind the Electrolytics
Besides this purpose . they made Good fuses & Shunt resistors
| FS: Black Gate "F" and "Nonpolar" caps | gripracer | Swap Meet | 3 | 10th December 2009 07:31 PM |
| What makes Nichicon "muse"/"for audio" caps different ? | percy | Parts | 2 | 3rd October 2009 05:53 PM |
| suspending a small tweeter in front of woofer for "coaxial" effect? | bikehorn | Multi-Way | 3 | 2nd January 2006 02:04 PM |
| Effect of cross-coupled "local" FB on plate load of previous stage | ray_moth | Tubes / Valves | 23 | 27th April 2005 08:55 AM |
| Which stuffing material to increase "perceived" enlosure size? | Two Moons | Multi-Way | 4 | 6th January 2002 04:27 PM |
