#51 | |
jaap |
#52 |
Not totally sure what you are saying here. Filament is usually one or two ohms added on to the cathode resistor - the DC filament supply goes through both the filament and the cathode resistor. The tube is biased at the voltage on top of the cathode resistor. This may be what you are saying? The total circuit is usually 5-50 ohms depending on the tube. I've been using filament bias for over a year on all input tubes. Resistor is 5 ohms on a 26 and 22.5 ohms on a 4P1L. I'm very happy with it.
#53 | |
1-2 ohms is when the filament is cold. Depending on the tube type, it rises to anywhere from 20 -80 ohms when the filament is hot. |
#54 |
I don't think so - we're talking directly heated tubes here. For a 4P1L it's 1.9v at 600mA which is 3 ohms.
#55 |
#56 |
You must excuse me but I have no idea what you are talking about. The last time I looked at ohms law 1.9v at 600mA was a resistance of 3.17 ohms. That's for a hot filament because unless I'm hallucinating, my amplifier is actually producing music.
#57 |
I have no doubt your amp is singing beautifuly. It's just the filament biasing that is interesting. Using a filament for a bias resistor is uncommon. I've seen it a few times but not with the tubes you are using. Your DHT filament power and biasing circuit would be interesting. When you use the term "filament biasing," I'm taking that to mean you use the filament resistance to bias some other tube's cathode. I've seen it done with 12ax7 type tube heaters to bias output tubes and use their cathode voltage to power the 12ax7 heater. Is your scheme different?
#58 |
Have a look at this:
#59 |
I thought the Coleman regulator board has an electrolytic cap (C15) from filament positive to ground?
Based on this version of Rod's (apologies if this is not representative of his latest/current design) New DHT heater Isn't that cap in effect acting like a cathode bypass? |
#60 | |
The regulator itself is not referenced to the ground at all. It connects between filament legs of the tube.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
| FS: Black Gate "F" and "Nonpolar" caps | gripracer | Swap Meet | 3 | 10th December 2009 07:31 PM |
| What makes Nichicon "muse"/"for audio" caps different ? | percy | Parts | 2 | 3rd October 2009 05:53 PM |
| suspending a small tweeter in front of woofer for "coaxial" effect? | bikehorn | Multi-Way | 3 | 2nd January 2006 02:04 PM |
| Effect of cross-coupled "local" FB on plate load of previous stage | ray_moth | Tubes / Valves | 23 | 27th April 2005 08:55 AM |
| Which stuffing material to increase "perceived" enlosure size? | Two Moons | Multi-Way | 4 | 6th January 2002 04:27 PM |
