ECC81 MU-Follower consumption
Old 7th October 2012, 10:15 PM   #1
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Default ECC81 MU-Follower consumption
How much current draws this ECC81 MU-Follower
http://www.freewebs.com/valvewizard1/Mufollower2.jpg
Old 7th October 2012, 10:18 PM   #2
Pic
Old 7th October 2012, 10:31 PM   #3
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
(183.7V - 85V) / 33k ohms = 2.99mA
Old 7th October 2012, 10:42 PM   #4
It's really strange, I'm using AZ1 with two diodes UF4007 as rectifier, regulators is the Salas SSHV2, when used a 15K dummy load all is OK can set B+ to +280V but when I connect the Mu-Follower the AZ1 shines a lot, I have the reg set to 32mA, the reg ned 20mA spare for the regs own proper consumption to good output impedance spec.
ECC81 MU-Follower consumptionHide this!Advertise here!
Mu follower MrCurwen Tubes / Valves 3 13th April 2011 12:46 PM
MU follower - distortion Brit01 Tubes / Valves 25 28th August 2010 12:44 AM
Cascoded mu-follower jnb Tubes / Valves 5 9th September 2007 11:28 PM
6DJ8/ECC88 mu-follower SSassen Tubes / Valves 30 11th April 2007 09:19 PM
Distortion analysis mu follower docali Tubes / Valves 12 7th April 2005 07:54 AM
Copyright ©1999-2017 diyAudio
