#21 |
Hey there,
I made some changes to the grounding scheme yesterday, the hum level is now significantly lower. The remaining hum disappears instantly on switching off the mains - so it's heater hum or PSU ripple. In principle, both should be distinguishable by the frequency, 100Hz for PSU ripple, 50Hz for heaters, am I right? Anyway, I am able to switch the mains for the HV supply and the heaters independently, so I can just try and find out which one makes the hum disappear instantly. Just forgot about that simple test yesterday, maybe it was a little too late in the evening ![]() Andreas |
#22 |
There are a number of hum ingress mechanisms - some have f fundamental, some have 2f fundamental. Sometimes its the harmonics of 2f that are most noticeable.
#23 |
Hey there,
I found time to get the scope out today, and found the following: Output hum into 8ohms: So there's roughly 1mV RMS hum into 8ohms on the output, with a frequency of 100Hz. Note the strange waveform: The hum is not sinusoidal, but looks like a full-wave rectified AC instead. There are short 'spikes' at the lowest parts of the waveform, too... Anyone seen such a waveform on the output of an amplifier before? Ideas about the origin of the hum? Checked the B+ rail for excessive ripple, but the 12mV RMS ripple I measured there seem reasonable: Sorry for the low image quality, multiple traces due to slow exposure time and low-frequency rail variations... Greetings, Andreas |
#24 |
Perhaps try a battery supply for input heaters - that would be my first check.
#25 | |
forgot to mention the following: a) Hum is instantly away when switching off the mains for the HV transformer b) Hum waveform remains unchanged when switching off the heater mains for a short moment. Andreas |
#26 |
Hmmm, for a common PT I'd try a humdinger pot on the heater - the mechanism of HT rectifier waveform coupling to heater winding is still valid for (a) and (b).
But I think you have two separate transformers? |
#27 | |
in fact, the test setup uses three different transformers: 1. 480-0-480, 180-0-180, 5 (+HV, -HV, rect. heater) 2. 6.3, 6.3 (-HV rect. heater, ECC88) 3. 6.3, 6.3 (EL34) The waveform of the hum very much looks like the current/voltage waveform I would expect between rectifier and 1st filter. I did not use twisted leads when setting up the power supply, maybe the rect.-filter connection couples into some high-impedance stuff in the amp circuit... Andreas |
#28 |
Were the scope shots with both inputs shorted to gnd? Have you checked some other simple circuitry 'exclusions' - eg. grounding the output stage signal inputs; replacing ccs with standard bypassed resistor. Then maybe DC heater, or humdinger pot.
#29 | |
Hey there,
They were made with the positive input shorted at the volume pot. The negative input is shorted to ground by default, as I do not have symmetric signal sources. Quote:
Can I simply ground the grids of the output stage for testing? Greetings, Andreas |
#30 |
ECC88 cathode - heater isolation shot?
Try exchanging tubes.
jaap |
| Trying to figure out the source of line-out hum | Fusion916 | Analogue Source | 1 | 6th March 2012 09:03 AM |
| Buzz Hum Aleph 5 with computer as source, no good results with GLI | zigo3 | Pass Labs | 3 | 20th February 2008 12:26 PM |
| source selector / volume hum in Aikido | cbutterworth | Tubes / Valves | 1 | 28th March 2007 07:34 AM |
| Looking for tips to identify hum source in a active crossover | ninjanki | Parts | 1 | 26th January 2006 09:17 AM |
| Need help locating right PMOS | borges | Analogue Source | 0 | 23rd February 2004 01:50 PM |
