One tube radio - diyAudio
Old 5th October 2012, 11:54 PM   #1
Default One tube radio
I was just reading a russian forum and I found this project. Its a radio receptor, with the tube 6ba6, I supose that its for AM or SW bands. I have some 6ba6 laying around here, so I decided to give a try to this radio. Anyone can explain to me how this works?
Note: I dont know how this coil have to be.. A conventional ferrite coil from a AM radio may work? And any chance to try a FM coil (if i change the variable to 5~60pf) ?
Old 6th October 2012, 12:51 AM   #2
Yes, that's an AM broadcast band setup. Change the tuning "tank" and it will work on the longer SW bands. The circuit is a grid leak detector, with regenerative (positive) feedback. The feedback control is adjusted to bring things just shy of oscillating. You will hear a "plop", when oscillation starts. Should that occur, you have to back all the way off and start over.
For a 1 tube FM setup, a super regenerative detector is in order. Look here.
Eli D.
Old 6th October 2012, 01:03 AM   #3
kevinkr's Avatar
Regenerative radio receivers can be a lot of fun, one thing to bear in mind is that they can (and often do) radiate RF on the antenna if allowed to actually oscillate which can be a problem when used for CW or SSB reception (badly in this case), since SW and BC bands generally use AM this should not be a problem.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 6th October 2012, 09:29 PM   #4
Haha I made it. Thanks for the replies =]
6BA6 Regenerative AM - YouTube
Building a tube radio JECalvert Tubes / Valves 17 16th July 2012 12:12 PM
Trying to identify an old radio tube mdalzell Tubes / Valves 7 15th June 2011 06:47 AM
Philips Tube radio Grifon Tubes / Valves 5 20th September 2007 03:40 AM
Help - tube radio JDeV Tubes / Valves 49 19th October 2006 08:18 PM
Another tube radio Magnetmaz Tubes / Valves 7 11th March 2003 06:01 PM
Copyright 1999-2017 diyAudio
