Old 10th October 2012, 06:17 PM   #31
ChrisA is offline ChrisA  United States
Originally Posted by kacernator View Post
Well, the preamp is intended to drive 100W class AB unity gain power buffer, so preamp output should be around 40V at full 100W output.
I do not know how to measure it properly, I mean why so different results? Is it the problem with DMM?
The output impedance is NOT constant over such a HUGE range. Your two test points are 15K and INFINITY. That is to large. Try two loads that are spaced closer like 15K and 150K or 15K and 20K
The output impedance depends on the operating point. Try 10K, 15K, 25K, 50K and so on and make a plot.
Old 10th October 2012, 07:11 PM   #32
Ok, I see now. Aikido preamp has flat output impedance within small output voltages, but impedance rises with higher output voltage swings. Basically what I needed to find out was if I measure correctly or not.
Thanks.
Measuring Output Impedance of Power Supply korneluk Tubes / Valves 21 27th December 2010 09:58 PM
How to calculate Tube Preamp output impedance? john65b Tubes / Valves 20 20th November 2007 02:44 PM
Measuring DC at preamp output square_wave Tubes / Valves 3 30th May 2007 01:44 PM
Low output impedance preamp needed. Dxvideo Solid State 10 13th April 2007 08:15 AM
Easy ways of measuring output impedance of tube stages stigla Tubes / Valves 4 16th May 2003 11:37 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
