Measuring preamp output impedance
Old 5th October 2012, 04:25 PM   #21
kevinkr's Avatar
Everyone has covered this pretty well, the large current swing at the output modulates the transconductance of the cathode follower and results in a varying output impedance and affects harmonic spectra at the output as well.. I'd say my suggestion to change the input impedance of the unity gain power amplifier stage to 50K would be a reasonable mitigation, provided that it actually dominates the input impedance. (With bipolar transistors unless heavily degenerated this will not necessarily be the case, so are you using fets or bipolars?) Can you post the actual circuit the Aikido is intended to drive.
I didn't check before posting the comment about the white cathode follower, in fact this circuit could potentially provide better performance than a CCS loaded CF. You'd have to test it to be sure.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 5th October 2012, 04:28 PM   #22
ruffrecords is offline ruffrecords  United Kingdom
ruffrecords's Avatar
Originally Posted by DF96 View Post
The small signal model is fine provided you have small signals. Part of the art of engineering is knowing which approximation to use, and not complaining that 'theory is wrong/useless' when the wrong approximation has been used instead of the right approximation. It is not the fault of the approximation if an engineer naively uses it outside its domain of applicability.
Exactly, and not realising this leads to the common erroneous assumption that (small signal) output impedance and drive capability are the same thing.
It is easy to design two different cathode followers operating at the same gm, one using a 12AX7 and another using a 12AU7. The small signal output impedance of both will be very much the same but the drive capability of the 12AU7 into, say, a 10K load will far exceed that of the 12AX7.
Cheers
Ian
Old 5th October 2012, 04:30 PM   #23
kevinkr's Avatar
Old 5th October 2012, 07:09 PM   #24
DF96 is offline DF96  England
Yes, and into a 100K load it could be that the 12AX7 has lower distortion. Hence asking things like "what is the best valve for a CF?" is in the same category as "what is the best length of string?", yet people continue to ask "best?" type questions.
Old 6th October 2012, 09:32 AM   #25
kacernator is offline kacernator  Czech Republic
To a first approximation output impedance will be 1/gm. gm varies with current, and therefore will vary with signal. All circuits have this problem to some extent. Good design minimises it, but cannot eliminate it, therefore output impedance will vary with signal.
An alternative point of view is that AC impedance is a small-signal phenomenon (strictly, for infinitesimally small signals only) and is undefined for large signals where non-linearity is an issue.
But the cathode follower works strictly in class A single-ended mode, so where is that current variation?
Old 6th October 2012, 09:45 AM   #26
disco is offline disco  Netherlands
disco's Avatar
What is meant here with current is the anode current, internal to the tube. Anode current changes value over the tubes' operation in amplifying the audio signal. It's a dynamic property, versus the static property you're thinking of (resulting from biassing, setting the tube working point).
jaap
Old 6th October 2012, 10:21 AM   #27
Still donīt get it, class A means that there is no current variation within the signal.
Old 6th October 2012, 11:03 AM   #28
jane is offline jane  Norway
jane's Avatar
No it doesn't.
Draw a loadline over the plate curves and you will see. As long as there is a load the loadline will not be horizontal and the plate and cathode current will depend on the signal.
Life is hard - Then you die.
Old 10th October 2012, 04:25 PM   #29
In class A the average (supply) current is constant, equal to the quiescent current and independent of the signal level, but the instantaneous current is not.
Cheers
Ian
Old 10th October 2012, 04:57 PM   #30
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
If there was no current variation, there would be no (ac) output current.
The ac output current is the difference between the instantaneous currents in the two output halves.
jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Measuring preamp output impedanceHide this!Advertise here!
Measuring Output Impedance of Power Supply korneluk Tubes / Valves 21 27th December 2010 09:58 PM
How to calculate Tube Preamp output impedance? john65b Tubes / Valves 20 20th November 2007 02:44 PM
Measuring DC at preamp output square_wave Tubes / Valves 3 30th May 2007 01:44 PM
Low output impedance preamp needed. Dxvideo Solid State 10 13th April 2007 08:15 AM
Easy ways of measuring output impedance of tube stages stigla Tubes / Valves 4 16th May 2003 11:37 AM
