Measuring preamp output impedance
Old 4th October 2012, 07:22 PM   #11
hollowstatefan is offline hollowstatefan  United States
Default Measuring preamp output impedance
If you want to drive unity buffer amps as you indicate, consider frequent contributor SY's ImPasse preamp, which was designed for exactly this kind of thing. SYclotron.com for more details. Also boards available from Company Store.
Old 4th October 2012, 07:27 PM   #12
kacernator is offline kacernator  Czech Republic
I donīt how Impasse preamp could solve my problem. There is no problem in aikido driving unity gain power buffer (for example F4).
Old 4th October 2012, 10:03 PM   #13
ruffrecords is offline ruffrecords  United Kingdom
ruffrecords's Avatar
The basic problem here is that the quoted 500 ohm output impedance is the small signal output impedance which is derived assuming the signal level is very small. As soon as you get to 2V or 5V rms you are no longer in the small signal regime and the 500 ohms therefore no longer applies. As you have seen, at higher signal levels the output impedance rises a lot.
Cheers
Ian
Old 5th October 2012, 07:57 AM   #14
disco is offline disco  Netherlands
disco's Avatar
So, output impedance is varying with output voltage? Hmmm.
jaap
Old 5th October 2012, 08:38 AM   #15
artosalo is offline artosalo  Finland
artosalo's Avatar
Kacernator, can you show your schematics ?
I would like to simulate a little.
Old 5th October 2012, 11:59 AM   #16
Why should output impedance very with output voltage? I donīt get it.
Here is the schematics, it is just plain aikido preamplifier.
Old 5th October 2012, 12:16 PM   #17
DF96 is offline DF96  England
To a first approximation output impedance will be 1/gm. gm varies with current, and therefore will vary with signal. All circuits have this problem to some extent. Good design minimises it, but cannot eliminate it, therefore output impedance will vary with signal.
An alternative point of view is that AC impedance is a small-signal phenomenon (strictly, for infinitesimally small signals only) and is undefined for large signals where non-linearity is an issue.
Old 5th October 2012, 12:46 PM   #18
TheGimp is offline TheGimp  United States
TheGimp's Avatar
The variation in gm with current is also the cause of distortion.
Old 5th October 2012, 01:09 PM   #19
disco's Avatar
My reasoning was quite simple: if two values exist for Rout (else than the sign), measured at differing operating points, the only explication can be you're measuring a variable and not a constant.
What I understand from Wikipedia the small signal model is an analysis technique while we (ought to) look at real world voltages. No 500 ohm Rout then.
Dave, is bandwith a complication for Rout? It's a non linear amplifier property as wel, diminishing with output power.
jaap
Old 5th October 2012, 03:28 PM   #20
There are not two values for Rout but an infinite set of values. The distinction between variables and constants is a fuzzy one. The only things in electronics which are really constant are things like the charge on an electron. However, for a well-designed circuit Rout will be roughly constant so we can calculate using it. It will, of course, vary with signal level and frequency and won't necessarily be a pure resistance.
The small signal model is fine provided you have small signals. Part of the art of engineering is knowing which approximation to use, and not complaining that 'theory is wrong/useless' when the wrong approximation has been used instead of the right approximation. It is not the fault of the approximation if an engineer naively uses it outside its domain of applicability.
Measuring preamp output impedanceHide this!Advertise here!
Measuring Output Impedance of Power Supply korneluk Tubes / Valves 21 27th December 2010 09:58 PM
How to calculate Tube Preamp output impedance? john65b Tubes / Valves 20 20th November 2007 02:44 PM
Measuring DC at preamp output square_wave Tubes / Valves 3 30th May 2007 01:44 PM
Low output impedance preamp needed. Dxvideo Solid State 10 13th April 2007 08:15 AM
Easy ways of measuring output impedance of tube stages stigla Tubes / Valves 4 16th May 2003 11:37 AM
