I have power but no sound??? - Page 2 - diyAudio
Old 13th October 2012, 12:12 PM   #11
Ok I've made some progress.. I've had a reply from the manufacturer:
"First test headphone, if only 1 channel have sound, this problem is one TDA2030 breakdown.
other problem please see the attachment delay circuit diagram."
I tested the headphone socket, which to be honest I hadn't thought to do... and I have just the right headphone playing music, whilst the left just hums. So this must narrow down the problem to TDA2030.... but whats this and what does it mean?
They also sent me a circuit diagram of the delay circuit if it helps at all.
Old 13th October 2012, 11:32 PM   #12
M Gregg is offline M Gregg  England
The TDA 2030,
Is a chip amp see this link for an idea:
http://www.itisff.it/dip_eln/tda2030.pdf
So you need to do a test to see if you can get a hum from a test lead when connected to the volume control.
If you connect a meter lead to the center tap of the volume control for the left and right channel you should get a hum this would tell you if the power section is faulty. if you dont get a hum then the fault could be one of the TDA2030 chips. Or the power supply to the chip amp for that channel.
So first does the chip amp work for the faulty channel.
If not is there a power supply to that amp? if yes then test to see if you get a hum if you connect a meter lead to the input of that channel amp.
If no hum from that channel then it could be the chip amp.
If you get a hum its in the pre section and the TDA2030 is OK.
You need to do these tests first..
Watch out for the B+ high voltage for the tube section..if you don't know what I'm talking about get an engineer to test it!
M. Gregg
High power Vs low power sound Moondog55 Multi-Way 3 12th April 2009 09:38 AM
+power-sound kornegirl Car Audio 0 29th January 2005 09:09 AM
kill sound with power off Doovieman Chip Amps 3 27th August 2004 10:53 PM
Amp power but no sound RaspberryDonut Car Audio 4 24th June 2004 06:21 PM
Power versus Sound Rob Dingen Pass Labs 4 10th April 2004 01:58 PM
Copyright 1999-2017 diyAudio
