Old 4th October 2012, 11:06 PM   #11
HollowState's Avatar
Originally Posted by macboy View Post
If you are using square waves, then the frequency doesn't matter at all, it could be a 1 Hz square wave and still suffer from degradation due to mismatched impedance. What matters is the highest frequency component of the square wave, which is determined by the rise/fall time of the edges, not the period (repetition frequency) of the square wave.
Geesh, always a technical stickler in the group. Yes, what you say is true for an ideal network on paper. But I was speaking from a practical standpoint to help jonnycat. Not to teach electrical engineering 101. Square wave degradition as frequency increases has mostly to do with the source generator, and maybe a little to do with the monitoring oscilloscope bandwidth.
At one time or another I have owned and used all of the better commercial bench oscillators. HP, Tek, Krohn Hite, Wavetek, Bruel & Kjaer, you name them. As you increase the frequency, the leading sharp corner rounds off and the waveshape looks less and less square the higher you go. No generator is perfect because they all have built in compromises.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University
Old 5th October 2012, 07:29 AM   #12
disco is offline disco  Netherlands
disco's Avatar
Originally Posted by HollowState View Post
... No generator is perfect because they all have built in compromises.
Thank you for pointing that out. This goes for popular computer (sound card) measurement as well?
jaap
Old 5th October 2012, 08:29 AM   #13
Originally Posted by tomchr View Post
Run a 10~20 kHz, 1 Vpp square wave into your oscilloscope (assuming you have one) with and without the terminator. Note the difference.
~Tom
They are both similar, but I did notice more "overshoot" at the beginning of the horizontal part of the square wave when I didn't use the terminator on the tee. Interesting!
Function Generator? TheDriver Parts 4 18th August 2008 09:46 AM
Looking for an used function generator Eva Swap Meet 0 21st February 2008 06:56 AM
Software function generator & SMD problem eeka chu Digital Source 1 3rd June 2004 08:40 PM
2-4 Watt Amp for Function Generator r_s_dhar Solid State 0 27th August 2002 04:37 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
