#21 |
LOL...didn't pay close attention to the pic.
Mundorf (M-Resist Supreme resistors) makes wire wound resistors that many feel are better than Mills. However, the values are limited and they are expensive. |
#22 |
However, C-comps have much less internal inductance, and are pretty much ideal resistances up to ~100MHz or so. Since grid/screen stoppers are RF components, you want the C-comps here (and for RF projects, if you do them as well). Otherwise, metal film for sensitive signal paths (less noise).
#23 |
So which c-comp resistor do you recommend? Thanks
#24 |
Hi Miles;
please answer my question honestly. For example you have an amp that has metal film resistors inside. You have in a drawer some C-comp resistors. How big is the chance that you open your amp and replace grid stoppers? Anatoliy
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#25 |
Are you saying that say a 5% different impedance at 1Mhz of a grid/screen stopper will impact the operation of the output stage for an audio amp?
#26 |
No, he's saying that the lower inductance construction of a carbon comp makes it more suitable as a grid stopper. I stopped using CC resistors altogether at least 20yrs ago and have found MF resistors to be generally effective, but there may be some instances where they are useful, and in VT RF applications they are the logical choice..
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
#27 |
Oh, I thought the inference was that because they were great for RF then they were ipso facto a requirement for stoppers in KT88 audio amps.
#28 |
try ferrite Beads
![]() v4lve |
#29 | |||
OK
#30 | |
To all those saying that carbon comp resisters change value with age and so on. Why worry they are only 20% tolerance devices. So even when they are new the value is kind of random, by 20% And this is good enough The big thing about CCs is the resistance varies based on the voltage across them. In other words they depart from Ohm's Law. But only by a small amount. The effect is a slight compression of the dynamic range. CCs also create some noise "hiss". The metal type are cleaner sounding and better for a HiFi amp. But hiss and compression as good in a musical instrument amp. |
| Aikido preams pcbs and various parts(tubes,capacitors,resistors,etc) | nicusim | Swap Meet | 3 | 7th June 2012 01:07 AM |
| JJ KT88s and other octals | kruesi | Tubes / Valves | 35 | 10th April 2011 06:52 AM |
| JJ KT88s for sale. | sts9fan | Swap Meet | 0 | 4th August 2009 07:38 PM |
| Genalex repro KT88s | bobgroger | Tubes / Valves | 3 | 30th September 2008 12:42 PM |
| KT88s and grid current | SpreadSpectrum | Tubes / Valves | 3 | 21st March 2008 07:33 PM |
