Hi~
I want to build GU 50 SE Amp. Anyone can help me. Suggest the circuit? Thanks |
#2 |
Search on this forum returns 214 topics where GU-50 was mentioned.
Welcome to the club!
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#3 | |
I just have the 6SN7 and GU50 tubes. Is the circuit no problem? Thanks |
#4 |
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. Last edited by Wavebourn; 2nd October 2012 at 07:03 PM. |
| GU50 Prototypes | matejsirk | Instruments and Amps | 12 | 14th May 2013 06:03 PM |
| My little SE with GU50 | matejsirk | Tubes / Valves | 20 | 28th January 2012 03:27 PM |
| EL152, GU50 and EL156 | eeyore | Tubes / Valves | 22 | 29th April 2010 07:58 AM |
| Gu50 | cristelu2006 | Tubes / Valves | 13 | 18th November 2009 10:29 PM |
| Gu50 Set ? | pwan | Tubes / Valves | 3 | 22nd April 2007 04:15 PM |
