Has anyone played around with this as an amp front end? - Page 3 - diyAudio
Old 7th May 2013, 02:13 PM   #21
pmillett's Avatar
Originally Posted by tubelab.com View Post
Another one has seen the light.
One little red driver board + 2 big Fuji mosfets + two unsuspecting output tubes = big power and low distortion.
The "low distortion" part is the one that surprises me... I expected to see more nastiness, but at least with what I've looked at so far, it's pretty nice!
I'm probably working almost an order of magnitude lower in power than you are, though
Old 7th May 2013, 04:20 PM   #22
Miles Prower's Avatar
It shouldn't. If you get that Vds up (attached) internal capacitance isn't a problem. In follower operation, the input capacitance problem goes away as the gate and source are at nearly the same potential, greatly reducing the current through Cgs.
Distortions aren't created equal. The very low output impedance, much lower than for any hollow state device (low single figures for Rd(on) ) goes a long way to get rid of a lot of distortion when taking any VT into Class *2 operation. The 1624 spec sheet gives some impressive THD figures, but with the provision that driver Zo not exceed 500R. That's quite an order for hollow state, but easily attainable with a source follower. Even slapping around screen grids is NBD for a MOSFET. Whatever distortion the MOSFET produces due to parametric frequency multiplication is of much less importance.
So far, me too, and cathode follower grid drivers have served well. I do have a project in mind that'll hit north of 100W, and for that, a source follower will be part of that design. It's a good idea even if not going for lotsawatts. Part of the problem with disappointing sonics from audio power triodes (especially the 300B) all seem to be related to insufficient grid drive, as these types can pull grid current even if the Vgk isn't actually taken into positive territory. They also have much higher Cmiller, since the plate and grid aren't shielded, and the reverse transfer capacitance is much larger than what you see with pents operating as pents.
There are no foxes in atheistholes
www.dolphin-hsl.com
Aleph J front end as pre amp??? audionut Pass Labs 2 2nd February 2012 04:32 AM
LME49811 front-end for Gilmore amp? Artie Solid State 7 29th April 2009 08:36 PM
a bit different amp front end layout ergo Solid State 9 24th March 2009 03:53 AM
Noisy EL84 amp needs new front end Charles Wasserf Tubes / Valves 2 10th September 2008 04:32 AM
Front end for sub amp mashaffer Solid State 9 22nd July 2005 03:35 AM
Copyright 1999-2017 diyAudio
