Help for  Dynavox VR-70E
Old 30th September 2012, 04:47 PM   #1
giavra is offline giavra  Greece
Default Help for Dynavox VR-70E
Hello I own this tube amplifier since i bought it new from the authorize dealer.All that time I've been listen the unit with the factory Chinize tube Electron tube EL34 B but now I buy a matched Quad of Mullard MULLARD Re-Issue EL34/6CA7 (Platinum Matched Quad) | eBay and I want to know if i must tune the bias for the new output tubes or just replace the tube without any bias tuning is there any danger of damage for the new tubes?
thanks
Old 1st October 2012, 01:35 PM   #2
palmas is offline palmas  Portugal
If it is a bias adjustable amp, you should always adjust bias at least when changing tubes.
This one (if I recall correctly) is via a voltage measurement of a 10Ohm resistor, set to 350mV..
Please check manual.
Old 1st October 2012, 05:30 PM   #3
Thank You for your reply but because i can't see any trimmer on the surface of the amplifier so if this amplifier can't tune the bias is it safe for the amplifier and for the new replace tube just to replace with out any tune.Also can you provide any more detail how i can tune the tube via (voltage measurement of a 10Ohm resistor, set to 350mV)?
Old 4th October 2012, 11:16 AM   #4
Verions my differ, but there were 4 big grey 10Ohm resistor and for RV inside.
Follow schematic and you'll get there. Try here:
++ verruecktedinge.de ++
Old 5th October 2012, 08:44 AM   #5
Despite the issue to find the resistor how I can tune it?Via multimeter?
Old 8th October 2012, 04:42 PM   #6
a multimeter or any voltage measuring device that can measure that kind of voltage accuratly
Help for  Dynavox VR-70EHide this!Advertise here!
Anyone owns a Dynavox VR-307 Amplifier ? lduarte1973 Instruments and Amps 11 26th November 2013 07:24 PM
Anyone used these dynavox woofers? Bill poster Multi-Way 13 18th April 2011 09:31 PM
Opinions: Dynavox TD2801XL kyrie48 Multi-Way 0 9th November 2008 01:52 AM
A tubeNoob enters => I bought a Dynavox VR-70E dgo Tubes / Valves 14 21st August 2006 07:25 AM
Dynavox tweeter RussianBlue Multi-Way 0 12th February 2004 06:58 PM
