Volume increases as amp warms up
Old 1st October 2012, 01:03 PM   #11
nkg is offline nkg  Australia
6SL7
Pin 2 268V
Pin 5 55V
I have checked both resistors and they are within their values re soldered the joints just to make sure but yes odd .
Old 1st October 2012, 01:10 PM   #12
DF96 is offline DF96  England
Check the driver grid voltages. Something is making one side of the valve take all the current.
Old 1st October 2012, 01:21 PM   #13
Pin1 -.059
Pin4 -.0 something multi meter won't settle down to a fixed reading .
Nigel
Old 1st October 2012, 01:50 PM   #14
Check the wiring around the phono control pot. There may be a ground connection missing, which would explain the wandering pin 4 voltage. The diagram is puzzling, as it seems to have that pot back to front.
Pin 1 seems a bit high at 59mV - could the valve be gassy?
Old 1st October 2012, 02:15 PM   #15
During the rebuild I left the phono circuit out . As far as the tube being gassy there is no visible blue glow and I don't have a valve checker but do suspect it could be a bit of a problem , may have to change it back to a 6SC7 and see what happens .
Nigel
Old 1st October 2012, 04:22 PM   #16
If you left out the phono circuit then you also left out the grid bias for pin 4. You need a 470k to ground, to take the place of the missing pot.
Old 2nd October 2012, 12:58 AM   #17
Ok will do that tonight when I get back from work.
Thanks Nigel.
Old 2nd October 2012, 01:02 PM   #18
Thank you for your advice DF96 it's been running for about twenty minutes now and all is fine . I will put the phono circuit back in and have ordered some better quality pots , these one's don't even fully turn off . I have made two two amps and a active crossover from scratch all of them worked so have not been able to develop any trouble shooting skills . I now can put my nos 6L6G's to see how they sound .
Thanks Again
Nigel
Old 2nd October 2012, 01:40 PM   #19
Glad it is now fixed.
Volume increases as amp warms upHide this!Advertise here!
marantz cd54 won't play unless it warms up isitrisky Digital Source 19 27th June 2014 06:04 PM
(Elector) New speaker material increases 'back [enclosure] volume' counter culture Everything Else 14 13th March 2012 11:34 PM
When playing music audio increases and decreases Sartic PC Based 5 2nd August 2011 11:56 PM
Amp Repair -- DC detector? Amp only works right at high volume? Help? danielwritesbac Solid State 9 2nd January 2008 06:05 PM
aleph5: only 3 irfp240 warms up fheanor Pass Labs 2 6th December 2004 07:44 AM
Copyright ©1999-2017 diyAudio
