New 6V6 Build - Suggestions Needed - Page 3 - diyAudio
Old 7th October 2012, 07:21 PM   #21
SandyG is offline SandyG  United States
SandyG's Avatar
Rongon -
The voltages measured were with all tubes installed, shorted input and an 8ohm load on the output. Sorry wasn't clear on how I called it out.
I changed the 270k plate resistor to a 150k, but I don't think made a difference on the quick test in the clipping department, but didn't have a bunch of time to really check things out.
I will give figuring out the load line in the chart and see how it works, which I'm guessing will yeild a different value of resistors for the phase inverter.
One thing that confuses me is where you use the where you mention plate voltage, and just to be sure that is the voltage measured at the plate of the tube after the dropping resistor or before for use in creating the new load line?
Go easy on me if these seem rudimentary questions
Pointy - I think I have a few other issues before looking at the filiment, I think my first guess parts selection are way off for setting up the operating points of the tube.
Sandy
Old 8th October 2012, 02:58 AM   #22
rongon is offline rongon  United States
rongon's Avatar
@SandyG
Plate voltage is measured right on the plates of the tubes, no resistors or anything else in the way. So on the 6SL7, the plates are pins 2 and 5, the cathodes are pins 3 and 6. The B+ is the voltage feeding the stage, so "above" the plate resistor. The voltage dropped across the tube's plate resistor will tell you the current being drawn through the tube.
So for instance, if the B+ is 325V, and you have a 150k plate resistor, and the plate voltage is 175V, that means 150V is being dropped across the 150k plate resistor. Now we can use Ohm's Law to figure out what current is going through the plate resistor (which will be the same as the current going through the tube). So...
150V divided by 150,000 ohms is
150/150,000 = .001 amperes, or 1mA
That would be a pretty decent operating point for a 6SL7, with plate volts (Vp) = 175V, grid volts (Vg) = -1.8V, and plate current (Ip) = 1mA
I'm not so much worried about the voltage amplifier (first stage). That's the simplest part. The part that would crunch driving the output tubes would be the cathodyne phase splitter. In push-pull amps, it's the phase splitter that is usually the weakest link. So I'm really interested in what the B+, Vp and Vk (cathode voltage) are.
When you draw the loadline, you take the B+ (voltage "above" the plate resistor) and divide that by the plate resistor value. So if you have a 325V B+, and a 150k plate resistor:
325/150,000 = .00217 A, or 21.7mA
On the 6SL7 curves, draw a line from 21.7mA on the left side (y axis), to 325V on the bottom (x axis).
The ideal loadline would be completely horizontal. The worst possible loadline would be vertical. In essence, the flatter the loadline, the lower the distortion.
Old 8th October 2012, 05:47 AM   #23
SandyG's Avatar
Rongon -
Thanks for all the help, it's almost sinking in! I will take a look at this as soon as I can catch a quick break.
I think you have slipped a decimal, should it not be 2.17ma? Max plate dissipation for each section of the tube is 2.3ma
Say my B+ is relatively fixed since I have the existing power supply, would the easiest way to go would be to target a specific current, i.e., 1.5ma and figure out the load resistors from that? My guess for the phase inverter would be in the 56k range but just a wild guess.
I'm going to have to get some time to do some more detailed measurement and then sit down with all the numbers.
Long day today again, hopefully I can get on it in the next day or so!
Sandy
Old 8th October 2012, 07:41 AM   #24
ChrisA is offline ChrisA  United States
The value of the plate load resister sets the slope of the line and hence the gain. You don't want to large of a load resider. 150K is about it. What you can do is add another RC section to the power supply. It is very much like what you said. Add a (say) 100K resister in series with the plate resister and connect the junction to ground with an (about) 20uF cap. This will drop volts and clean up the power and break a feedback path. If this is already done then just make the power supply resister larger.
In other words the best way to drop volts is to add another RC filter stage. Or just make the R larger.
Old 8th October 2012, 01:21 PM   #25
rongon's Avatar
Yes, I had a brain fart last night! 2.17mA is correct, *not* 21.7!
Sandy
You want the load line to be relatively horizontal. The rp (internal plate resistance of the tube) of a 6SL7 is well over 60k ohms, and generally speaking, you want the Rp (load resistor) to be at least 2x the tube's rp. When designing for a common cathode voltage amplifier, it's usual to aim for an Rp of at least 4x the tube's rp. So 56k would be too small a value plate resistor for a 6SL7. I think 100k ohms would be the absolute minimum.
I think you'll find that the difficulty is caused by having such a low B+. 320V is pretty low for a 6SL7. It would be a low B+ for a 6SN7 too. I think you're going to find that you need to operate the tubes with lower than optimal Ip (plate current), because of the lower than optimal B+.
ChrisA and I apparently do not agree. I don't know who is right. My opinion is that you don't want to drop volts, you need as high a B+ as you can get, so you have some volts to drop across the plate and cathode load resistors of your cathodyne. As in a cathode follower, you want the stage to be as linear as possible *before* you add the negative feedback.
Also, putting an additional RC decoupling between the input voltage amp and the cathodyne can result in motorboating (low frequency oscillation). If the input amp is DC coupled to the cathodyne input, it is common for those two stages to share a common B+ supply feed. See Morgan Jones' discussion of his Bevois Valley amplifier in Valve Amplifiers 3rd Ed. (pp 444-455).
But ChrisA may be correct and I may be wrong. I don't know.
Old 8th October 2012, 01:49 PM   #26
rongon's Avatar
I drew the loadline for B+ = +325V, plate load resistor (Rp) = 150k ohms.
Notice that I labeled the plate voltage as Vp-k. That's voltage from plate to cathode. That will become important when you draw a loadline for the cathodyne, as the cathode will be somewhere around 100V above ground.
Old 8th October 2012, 02:08 PM   #27
Bigun is offline Bigun  Canada
Bigun's Avatar
I don't know if you have the space, but a choke instead of a resistor for the 6SL7 anode would allow more headroom. Hammond makes a 150H choke that might just be enough and is relatively inexpensive. The 6SN7 would be the first thing to try though, although it likes a high B+ for best linearity, it has a much lower plate resistance than the 6SL7.
If you could bear the thought of re-wiring, you could also try a combination, 6SL7 up front for gain, 6SN7 for phase splitter for more drive.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 8th October 2012, 02:15 PM   #28
rongon's Avatar
OK, let's say we have that same +325V B+ available for the 6SL7 cathodyne. We'll now want to draw a loadline for that, Let's say we have a plate load resistor (Rp) of 100k, and a cathode load resistor of 100k (Rk).
Since the current will be the same at all points in the circuit (Kirchoff's Law), then we can divide the B+ by 3, so 325/3 = 108 (approx, close enough)
100,000 x .00108 = 108V dropped across each 100k ohm resistor. (Wasn't that convenient?)
The voltage at the 6SL7 cathode will be +108V.
The voltage at the 6SL7 plate will be +216V.
The B+ will be +324V (close enough to 325 for our purposes).
As you can see, the voltage from the 6SL7 plate to cathode will be only 108V. The "B+" the 6SL7 will "see" will be from the cathode to the B+, which is 216V.
So, to draw the loadline, we use values of 216V and 100k ohms.
216V divided by 100,000 = 2.16mA ( NOT 21.6!!! )
I added (in brown) loadline for 182k ohms for plate and cathode load resistors.
These loadlines are attached.
Did I do that right??
I don't think the cathodyne will have to supply much current drive for 6V6 pentode outputs, so maybe a 6SL7 will do here. But it shouldn't be run with near zero bias, where the 6SL7 will be likely to start drawing current through its grid. That would load down the previous stage, which would not be good. My understanding is that high mu tubes like 6SL7 draw appreciable grid current when biased with anything less than about -1V at the grid. That's how they can be used with grid leak bias (a huge grid resistor and no cathode resistor). We don't want that happening in the cathodyne phase splitter, do we...
Old 8th October 2012, 02:41 PM   #29
rongon's Avatar
Good points all!
If you wanted to get really slick, why not a DN2540 FET as the plate load for the first stage?
But I don't think the first stage is the problem. I think the problem is the cathodyne phase splitter. Let's see if a 6SN7 would work better there...
Well, I tried 15k for the plate and cathode load R's, but I came up with very little swing available. Maybe enough to drive 6V6's, though. With 15k load resistors, the 6SN7 operating current winds up at 7.2mA, which isn't bad. The only thing is I again worry about the tube needing to swing to near zero volts at its input, causing grid current, causing the input tube to go *crunch*.
With 22k (shown), the 6SN7 internal current is about 5mA (probably will be more like 4.9mA), which isn't as good, but isn't horrible. It swings more volts this way.
Swapping in a 6SN7 instead of the 6SL7 opens a new can of worms. The problem is that the gain of a 6SN7 common cathode stage with resistor plate load will be about 15x. So, with only +325V B+, the grid bias on that first stage 6SN7 is bound to be kind of low. So let's say it's -2V and the highest peak input (AC signal) voltage will be 1.7V. 1.7 x 15 = 25.5 volts out, but the cathodyne has actually less than 1x gain. Let's say 0.9. So, 25.5 x 0.9 = 22.95 volts out to drive the 6V6's. That's just barely enough, no headroom to speak of. That's the problem with swapping in the 6SN7 in place of the 6SL7.
In the end, I think Bigun's suggestion of a 6SL7 for the input voltage amplifier stage and 6SN7 for the cathodyne is the better way to go. The trick is to get the grid bias of the 6SL7 to about –1.5V, both so that you can give it enough input signal and so that it doesn't draw too much grid current (if too close to zero bias).
Last edited by rongon; 8th October 2012 at 03:09 PM. Reason: more afterthoughts...
Old 8th October 2012, 03:07 PM   #30
rongon's Avatar
In the first post, you posted the voltages you got as:
HV1 - 327 - B+
HV2 - 326 - Phase Inverter Stage
HV3 - 286 - Input Stage
V1PA - 65 - Input Plate Voltage
V1PB - 253 - Phase Inverter Plate Voltage
If cathodyne HV2 is +326V, and its plate voltage is +253V...
326 - 253 = 73
That's 0.73mA across the 100k plate resistor, so in accordance with Kirchoff, 0.73 being drawn by the tube too.
100k resistors in the plate and cathode, correct? That would mean 73V dropped across both the plate resistor and cathode resistor. So 73 x 2 = 146.
326 - 146 = 180.
That means there is 180V from the 6SL7's plate to its cathode ("across the tube").
This does not add up. But if it does add up, and the tube is actually different than the published curves, it still means the 6SL7 is being run down near cutoff (where it stops conducting), and won't swing many volts before going *crunch*.
So you see, we need to verify those voltage readings you got. They don't look good...
Build guitar amp with 2 6L6 or 4 6V6? TubeTweaker Instruments and Amps 11 15th August 2012 12:01 PM
Advice needed on new 6L6 ro 6V6 SE or SET build GloBug Tubes / Valves 39 23rd November 2011 04:22 PM
A little help with 6v6 screen needed. lazzer408 Tubes / Valves 15 28th February 2011 07:32 PM
At Last....First Build Complete...6V6/6SL7 cbj591 Tubes / Valves 9 31st July 2010 01:51 AM
6v6 music machine build help! tubo Tubes / Valves 26 5th November 2009 04:34 PM
Copyright 1999-2017 diyAudio
