Hrrrrmphhhff. PSU design error and how to cope with it
Old 28th September 2012, 05:20 PM   #11
12E1 is offline 12E1  United Kingdom
12E1's Avatar
Originally Posted by DF96 View Post
If your two HT secondaries are identical then parallel them and feed two GZ34 in parallel. This like your option (b) except the anodes are arranged differently. Avoids hum problem during warm-up, but at the expense of GZ34 overloading during warm-up during the few seconds when only one may be hot enough to function. No worse than (a) though, and only for a few seconds.
Rather than putting the windings directly in parallel I'd put a resistor in series with each rectifier anode. This helps with load balancing between the windings if they are not quite equal in voltage and would possibly also help to ensure that the valve's requirement for a minimum source resistance is met (helps to limit the charging spikes into capacitive loads).
Hrrrrmphhhff. PSU design error and how to cope with itHide this!Advertise here!
Marantz CD63 KI SIG, Error 12, Sled Error problem sisik Digital Source 1 9th November 2008 03:12 PM
Modifying CMOY to cope with switching power mattkosem Chip Amps 16 7th September 2008 10:26 PM
PSU Design help wildbill Power Supplies 3 17th March 2006 07:02 PM
I need a schematic for a tubed crossover that can cope with 10k load impedance?!? hifi Tubes / Valves 7 16th August 2004 07:26 PM
Whats worse, 1db error in response curve or a phase error of 6? primalsea Multi-Way 5 13th May 2003 01:24 AM
Copyright ©1999-2017 diyAudio
