How to understand the power output in this case? - diyAudio
Old 27th September 2012, 04:35 AM   #1
hungdn is offline hungdn  Viet Nam
Default How to understand the power output in this case?
Hi folks,
I learnt in duncanamp that EL34 PP AB1 class can produce power to 100W/ch.
Class AB1 P/P
Va 775
Vg2 400
Vg1 -39
Ia 50 - 182
Ig2 6.0 - 38.0
Ra
S
Rk
Zout 11,000
Pout 100
THD 5
Notes Shared Rg2 = 750 ohms
Since max dissipation power of EL34 is just only 25W/valve, therefore, PP with 2 valves per channel can only produces max 50W/ch. So why the output power is so great? Is this the parallel PP in this case?
Thanks!
Old 27th September 2012, 06:59 AM   #2
jan.didden's Avatar
The dissipation of a tube is not the same as the max output power.
The dissipation is the loss of power that heats the tube, but the output power in class (A)B can be higher.
jan didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 27th September 2012, 09:00 AM   #3
payloadde's Avatar
Class A:
Maximum theoretical efficiency is 50%.
Class B push-pull:
Maximum theoretical efficiency is 78.5%.
Judge: This court appreciates that you invented physics, Mr.Newton, but unfortunately you can't have a patent on it.
Old 27th September 2012, 12:20 PM   #4
the_manta's Avatar
Originally Posted by hungdn View Post
Hi folks,
Class AB1 P/P
Va 775
Vg2 400
Vg1 -39
Ia 50 - 182
Ig2 6.0 - 38.0
Ra
S
Rk
Zout 11,000
Pout 100
THD 5
Thanks!
The key point is to use Class-B and to max out the tube's Ub: The mean value of the plate dissipation has to be <25W for a whole cycle (EL34). But this is regardless of the exact distribution in this interval of the cycle. So you can go well above the Pa-max hyperbola for some small time interval. This can be proven mathematically quite easy when you assume a sinusoidal signal.
Below you see the EL34 curves for the Operating conditions you published in your post. At the hottest point, the EL34 "burns" over 60W on its plate - not a problem.
I hope, you kind of got the point how this works.
Терпенье и труд все перетрут
Old 27th September 2012, 05:50 PM   #5
Thanks all. Since I am a newbie to electronic and trying to design my first tube amp schematic , so all your information is value to me.
A question for the_manta:
As I see in the datasheet of TLF EL34,
Max anode voltage = 800V
Max anode current = .15A
So I dont understand that why the load-line is come from the point (0V,320mA)?
As your explanation, I understood that in AB class, the tubes are working alternately, so in the given short time, output power of the tube can greater than the max dissipation rate. So is there any formula or something in the datasheet can help me to calculate that?
Thanks so much for your help
Old 27th September 2012, 07:20 PM   #6
the_manta's Avatar
I appreciate the fact, that you want to learn more about tube operation
But you should know, that this operation principle applies for Class-B operation. Like when you have to squeeze everything out of a tube. Distortion is unimportant in such a case. Nowadays, Class A or warm Class AB operation is prefered.
Also your data is not Class-AB anymore, it is Class-B, as also pointed out in the Telefunken or Philips Datasheet. (The well known 800V/100W/11K-Raa operating point)
I made a small mistake there ! I misread your given value and used 10K-Raa and 800V for the picture.
It's easy. For Class-B operation, Raa = 4*Ra (The total resistance of the output transformer has to be 4 times the value of a single tube. (For Class-A it is 2 times!). Reason: Always only one tube conducting instead of 2 tubes in Class-A)
So Ra= Raa/4 = 11K/4 = 2,75K
Furthermore: Ra=Ub_max/Ia_peak
rearrange: Ia_peak = Ub_max/Ra = 775V/2,75K = ~282mA (instead of 320mA as I drew)
This would take a very long time here. I suggest some good books here:
Sadly I only have german literature for this case: http://radau5.ch/pdf_files/anwend_3.pdf
The concept behind this: Use a power ansatz:
P_anode = P_supply - P_out
So you're left with finding P_supply and P_out. But, you have to find them in a way, that you maximize P_out and that P_anode matches P_anode_max (25W for EL34). So this leads to a derivation of your P_anode function to find the maximum etc....
I don't have classic Litarure in English language, just german. Maybe someone here can give some advice where you can find the proper PDF.
But, again: For a good, low-distortion tube amp you don't need to know this. Class-A Push Pull is unbeaten when it comes to THD and the math behind this is easy.
Old 28th September 2012, 12:52 AM   #7
@the_manta: Thank you so much for your time. So much clear for me.
Please help me understand power supply load deuce42 Tubes / Valves 6 6th January 2012 06:07 AM
trying to understand power... Ryanschmidt224 Multi-Way 21 3rd May 2011 07:16 PM
DIY Audio Alchemy Power Station 2 Power supply PSU with case roscoeiii Swap Meet 2 29th May 2010 06:51 PM
Trying to understand the Naim Armagedon power supply, please help pjpoes Analogue Source 2 14th January 2007 04:38 PM
How to understand Output voltage gain graphics screwdriver Chip Amps 0 29th August 2004 07:56 AM
Copyright 1999-2017 diyAudio
