I'm making amplifier chassis for myself and others using select
hardwoods with dovetail joints for strength. I don't know if you've
thought about wood for a base but it has some great structural and
aesthetic properties. If you might be interested let me know your
specifications and preferences. Thanks
scottnaylormail@gmail.com
Have you looked at yaegeraudio.com?
That's not too bad for having a fuse and IEC receptacle already installed along with a vented bottom plus feet. They're even based in the US!
E-mail sent.. interested in a chassis...
Bob
Any recommendations? Would be a larger amp... about 100 Watts mono ( so not a small unit ) and need several made... First a few prototypes, then might a small run of 20. Would need other sheet metal parts made too.
This is a group build for a few locals in the area....
jk
sending you a pm, might have a great deal for you on 10 bare bone kits (chasis, xfomers, power tubes, driver tubes)
- Tubes / Valves
- custom Tube chassis vendor
