Hi
Has anyone here used one of these???
http://tubedata.tubes.se/sheets/061/s/S102-1G.pdf
I picked up a few a while ago and wondered how they operate the relay and then switch off, cant quite picture how a relay will hold the circuit closed with no coil current, other than latching....but then you have the issue of resetting the relay to switch off the circuit
I'm confussed!
I'm confussed!
It's like a thermostat. It closes when hot and opens when cold. The "coil" is a heater.
When current is applied through the heater, it takes a certain amount of time to heat up then close the contact hence the delay. When the current is turned off, It takes a certain amount of time to cool off before opening.
That's how I think it works
The one I used has a biometalic strip which switches the +B load of about 200mA at 350V. The tube I use is wired in series with the power supply (+B) and the drain resistor applies the initial heater current to switch it. Delay is about 10secs in this configuration. Maybe a slightly different type to the ones you have.
Shoog
Shoog
Hi Snoog
Yeah I know these circuits are all over the web but I was just keen to get another piece of glowing glass into my projects
I just can't see how the relay will reset once triggered by the thermal switch??
Cheers
Just as in the transistor circuit - the relay unlatches as soon as the mains power is disconnected.
Shoog
Hi Snoog
Cheers
I have some of these too. They use a bimetal strip that bends when heated due to applied current. They are quite slow in operation (not like the snap action of a relay) so they are not suitable for high HT voltages.
Also, the bimetal takes about 500mA of heater current to operate (and that is needed continuously) so they are a mixed blessing.
Gary
- Tubes / Valves
- VLS631 Thermal Delay
