#31 |
So, add another gain stage?
#32 |
The amplifier is finished!
, the sounds is so great!Wow, Wow, Wow ![]() ![]() I did not use any feedback since I don't like it (it flattens the bandwidth). ![]() ![]()
#33 |
There is no need to add any extra gain stage, the gain is more than enough, tested!
#34 |
#35 |
Hi pilovis.
Beautiful assembly and great case. I have a couple of concerns though. I assume that the larger white transformer is the main line-power transformer, and the two black transformers are output transformers. If you connect large loudspeakers with good bass response, and you might hear more 50Hz hum in one channel than in the other that could be because the middle output transformer is mounted parallel to the line transformer. If you turn that transformer around 90 Degrees you will probably find that the hum is reduced. A second comment is that I believe that the rectifier tube is too close to the power output tube 807. During operation the two tubes would heat each other up and may overheat the glass where they almost touch. Power-tubes like these should not be closer to each other than about 20mm. Congratulations on a beautiful construction. Hans J Weedon. Last edited by HJWeedon; 10th October 2012 at 11:32 AM. |
#36 | |
I will add a small internal fan. Fortunately, there is no udible hum. This is the video I took with my small digital camera : 807 tube Ultralinear Class A - Stereo Hi-Fi Amplifier - YouTube and just another picture:
#37 |
I listened to this amplifier connected to a pair of huge Warfedale E90, 100 kilograms of speakers
![]() Wow, It was amazing, at almost full volume (7+7W), the room was full of sound with no audible distortion and very good quality of sound! Someone told me this amplifier wouldn't have enough gain, some other told me the penthode driver wouldn't have a good sound .No comments ![]() Warfedale E90
#38 |
The trick of the gain is in the capacitor between the driver's screen grid and ground
| Paralell SE 807 Amp design | mossmamc | Tubes / Valves | 65 | 16th December 2011 09:38 PM |
| G-807=807 SE or PP? | gabrielbecheanu | Tubes / Valves | 8 | 18th July 2010 11:57 PM |
| 807 SE amp schematic | cjng74 | Tubes / Valves | 1 | 30th January 2009 08:26 AM |
| Help in SE 807 amp | alejo | Tubes / Valves | 16 | 15th January 2005 07:25 PM |
