Old 25th September 2012, 12:17 AM   #11
pilovis is offline pilovis  Italy
Originally Posted by SY View Post
The gain seems mighty low...
the 6G6G gain or the total gain?
Old 25th September 2012, 12:50 AM   #12
the_manta's Avatar
If you want more Power, you can go up to 350V on the 807 anode without any problems for 5K load resistance. I tested a few OPs and 350V;5K sounded best. (250V;2.5K was worst)....just my experience
Doesn't matter because you have global feedback. Increase your feedback resistor and the 6G6 load resistance. They form a voltage divider which determines the feedback ratio.
ATM your global amplification is only about ~3
The fact, that this kind of feedback never pleased my ears is another thing....but, well, find that out for yourself
Терпенье и труд все перетрут
Old 25th September 2012, 02:13 AM   #13
Hi This is fun.
Using tubes way outside their specified operating range. The 807 is OK biased maybe for a little too much plate dissipation - 15V on the grid would be a little kinder to the plate, it is over-dissipating by a bit, but for a big tube like that, it is acceptable. The 6G6 is more troublesome, because it is used way outside its specified range of operation. It is a power pentode used as a low current voltage amplifier. From the RCA book we can estimate that an acceptable operating point for the 6G6 would be about 2mA in the plate and 0.3mA in the screen grid (ratio of 6 to one). All fits the resistor values chosen. An effectively negative grid voltage of 3 volts on the control grid should be proper at 2.3mA the cathode bias resistor should be in the range of 1.2k or there about. Maybe the LEDs would work just fine, but please bypass them with the 220uF cap. I would prefer a 1.2k resistor though.
This amplifier should work just fine and sound good too. It uses negative feedback around the output tube. That lowers the source impedance as seen by the output transformer. Transformers are voltage conveying devices and work best when driven by a low impedance source.
Thank you for the schematic.
Hans J Weedon.
Last edited by HJWeedon; 25th September 2012 at 02:17 AM. Reason: just a few corrections.
Old 25th September 2012, 02:19 AM   #14
the_manta's Avatar
Why ?
That was the reason he used LEDs in the first place - to get rid of the cap. This works great, just be sure to get at least 5mA through them.
Old 25th September 2012, 02:30 AM   #15
There is no way of getting 5mA in the LEDs max 2.5mA, and why get rid of the cap?
I know that caps have a "bad" reputation in audio circuits, but when they are used correctly they are just fine. From my experience a film capacitor versus an electrolytic changed the distortion from 0.001% to 0.0015%, measurable, yes, but not audible under any circumstances.
Hans J Weedon
PS: I have done "high end Audio" stuff for over 60 years by now and I do know what I am talking about.
Old 25th September 2012, 02:34 AM   #16
SY's Avatar
A bypass cap across the LEDs is superfluous- they might contribute 7 ohms or so impedance, hardly enough to worry about.
Gain from in to the output transformer is about 3, but your output transformer steps things down as well, by a factor of 25. That's a problem.
If there's a sucker born every minute, where do the rest of them come from?
Old 25th September 2012, 06:10 AM   #17
and what about this modified schematic to easily change the output tube just setting the right value for bias voltage?
I like experimenting
Anyway, I increased the load resistor of 6G6G and the feedback resistor to have a little more gain, also added cap in parallel of the two leds, it may helps.
Old 25th September 2012, 07:29 AM   #18
The cap across the leds ? gives you a little more gain gives a few other IMHO setbacks.
If you´re turning it into a testbed fo swtiching tubes you need variable level of feedback to match the tubetype and mode.
And bias still needs filtering.
Old 25th September 2012, 11:21 AM   #19
Feedback is already variable, please note the pot in series to the other two resistors in the bias line.
Old 25th September 2012, 03:31 PM   #20
SY's Avatar
No, not significantly. The cap can only do bad things there, if it does anything.
Paralell SE 807 Amp design mossmamc Tubes / Valves 65 16th December 2011 09:38 PM
G-807=807 SE or PP? gabrielbecheanu Tubes / Valves 8 18th July 2010 11:57 PM
807 SE amp schematic cjng74 Tubes / Valves 1 30th January 2009 08:26 AM
Help in SE 807 amp alejo Tubes / Valves 16 15th January 2005 07:25 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
