Glowing Plates of Doom
Old 25th September 2012, 11:58 AM   #21
TV7 is offline TV7  Australia
TV7's Avatar
Originally Posted by HJWeedon View Post
Hi again TV7
After further thought I believe that putting a 0.001uF cap inside the RIAA feedback loop is a very bad idea. This is how good designs gets ruined and propagate into the world of circuits. Please find a proper way to stop the 1.8MHz oscillation, my bet is on the power-rails not being bypassed properly. By loading the loop-gain with a 1000pF there will be nothing left to track the RIAA components.
Hans J Weedon
Thanks Hans, please elaborate on the power rails not being bypassed properly, not sure if I follow you.
thanks
First things first, but not necessarily in that order.
Old 25th September 2012, 05:56 PM   #22
tomchr is offline tomchr  Canada
tomchr's Avatar
+1 on the grid stoppers and supply bypassing. Another way to approach this would be with an "anode stopper". I.e. a small RF choke or resistor in series with the anode. Same can be applied on the cathode. Also consider coupling the heater circuit to the chassis ground with a 1 nF ceramic cap from each heater pin to the chassis right at the tube socket.
~Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 25th September 2012, 11:02 PM   #23
pointy is offline pointy  United Kingdom
pointy's Avatar
have you tried to bandpass out everything above human hearing to give your tweeters an easy time of it....
Old 26th September 2012, 01:26 AM   #24
tomchr's Avatar
Addressing the problem at the source would probably be a better solution...
~Tom
Old 26th September 2012, 09:15 AM   #25
DF96 is offline DF96  England
I doubt if tweeters are too bothered by 1.8MHz. You would need professional ultrasonic transducers to deal with that!!
Old 26th September 2012, 10:25 AM   #26
palmas is offline palmas  Portugal
Tweeters would not reproduce that, but would heat up!
Old 26th September 2012, 10:40 AM   #27
On Hiatus
SY's Avatar
What's the impedance of a tweeter at 1.8 MHz?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 26th September 2012, 12:56 PM   #28
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Originally Posted by TV7 View Post
Will try the solutions and the 12AU7 Hans, although how would a series signal resistor of 10K to 47K affect the CF bias?, possibly some. Maybe not at all? Thanks
Since the grid does not conduct current, the GS resistor only functions with the miller capacitance to form a low pass filter far above the audio range.
Try a smaller cap for your suppression cap instead of 0.001uF.
I've found in some cases as little as 47pf g-k can be effective in guitar amps.
I'd go for the stop resistors on all grids first though.
Old 26th September 2012, 03:21 PM   #29
Rundmaus is offline Rundmaus  Germany
Rundmaus's Avatar
Hey there,
good to hear that the problem could be located - although the cure currently in place is a little drastic...
Apart from that the description of the whole event (red-plating power amp and such) makes me think it would make sense to take precautions for sources or preamps behaving bad.
Even if a bad source / preamp feeds a high-amplitude 1,8MHz signal into the input of the power amp, it should be taken care that this RF is *not* being amplified, driving the O/P stage to its dissipation limits and beyond. I think proper limiting of the power amp frequency response below the RF range won't hurt...
Greetings,
Andreas
Old 26th September 2012, 04:37 PM   #30
HJWeedon is offline HJWeedon  United States
hI tv7.
This morning I did a computer simulation of the RIAA preamp as drawn. My simulation shows that without the 10k/1nF capacitor you put in, the circuit does indeed want to oscillate. My simulation wanted to oscillate at 8MHz, but that is sort of arbitrary and depends heavily on layout and such. The important point is that 10k/1nF does stop the loop oscillation. It also shows that it is not the classical VHF parasitic oscillations that tubes often show, but the actual feedback loop that oscillates.
The loop gain is a little low at low frequency, about 5dB, but you can easily boost that to 10dB giving a little better tracking to the RIAA curve by changing the plate resistor in the first 12AX7 stage to 47k. since that stage is AC coupled, you do not need to do anything else. With that gain change, you should also double the oscillation taming capacitor from 0.001uF or 1nF to 2.2nF.
Good luck and have a good day.
Hans J Weedon.
PS: The surprise to me was that what I thought was a drastic change was actually required for stabilizing the feedback loop.
Actually with the gain-increase a little bit better loop compensation would be to use the 1nF capacitor, but with a 470 Ohm resistor in series to ground. Resistors do good things at times. This is called pole/zero compensation
HJW.
Glowing Plates of DoomHide this!Advertise here!
Video: Our 2011 HomeMade Horn Of Doom Build stimmedmarine Everything Else 0 25th November 2011 01:13 PM
Plates glowing on my Fender Concert after blowing fuse nooel Instruments and Amps 63 1st August 2011 07:44 AM
what just happened? Plate glowing jrenkin Tubes / Valves 15 20th December 2009 05:06 PM
Screen glowing? jjman Tubes / Valves 1 24th November 2009 01:28 AM
