Modding Aikido to non-Aikido such as SRPP?
Old 24th September 2012, 12:09 AM   #1
Doug Kim is offline Doug Kim  South Korea
Doug Kim's Avatar
Default Modding Aikido to non-Aikido such as SRPP?
Hi there,
I planned Aikido (6SN7) preamp long time ago, and collected many good parts: dual mono power supplies (DC heater, CLC HV), stepped attenuator volume, relay selector board, very nice chassis, etc.
I finally had some time during this Summer and finished it, but with big disappointment. There's hum, and it increases as I turn the volume. I have much experience with many different types of analog electronics, I have read almost all threads related to removing hum of Aikido, but I am now out of my patience now.
It would be greatly appreciated if someone can suggest me a spot-on tip to remove hum from Aikido which increases as the volume turned.
But I would also like to ask if there has been anyone converted Aikido (6SN7) to other pre circuit such as SRPP. I have 300V B+ and 6V heater. I wouldn't mind using only one 6SN7 per channel.
Thanks in advance,
Doug
Modding Aikido to non-Aikido such as SRPP?Hide this!Advertise here!
Max anode voltage and srpp/aikido amps Globulator Tubes / Valves 0 29th February 2012 07:09 PM
Preamp tube SRPP 12AU7 VS preamp tube Aikido 12AU7 = all use rec 6X5GT spiritm2r Tubes / Valves 1 6th March 2011 03:53 PM
Aikido HiFiNutNut Swap Meet 1 24th January 2007 05:26 AM
Replacing cathode resistors of Aikido 1st stage (or other SRPP circuit) with chokes snoopyma Tubes / Valves 1 31st July 2006 06:21 PM
Copyright ©1999-2017 diyAudio
