ok so i just have two tiny double A batteries and a low power 50 watt 12 inch old subwoofer
i have a wire set just touching the middle of one lead from the positive side of the battery so that it keeps a constant on and off signal and the negative side of the battery goes directly to the other lead..and in between the positive side of the battery and the wire that goes to the (middle of the lead that goes to the speaker) i have a transformer that converts the voltage to a higher voltage how this works is when the power from the batteries hits the subwoofer.. the speaker moves up and since the lead is only touching the wire that goes to the battery but not staying connected to it. once the speaker goes back down to its resting place the speaker is hit again from the voltage of the batteries and the cycle is repeated and in doing so it produces a sort of AC? the switching speed is low enough to be around 50-60hz it's as close as i can get also i tested the transformer and it does indeed produce very high voltage of over 90 volts at the output side!! when i hook something up to the output of the transformer it makes sparks go flyin for a half second when i connect the output to some other high voltage device! is there some way to simplify this into a smaller circuit with the same output or better output results? there is no resistors diodes transistors or capacitors in this DC to AC circuit I made! and it works pretty darn good and doesn't drain the batteries too much at all it's been running for about an hour hooked up to a high voltage lamp and it's been going strong for a long time and still going (although the noise from the subwoofer is annoying I managed to block out the sound somewhat and somehow even though its so noisy my mom is able to sleep on the couch right next to me haha so does anyone think that this could be useful somehow? |
#2 |
That sounds like the doorbell plus transformer which I used as a youngster (12 or 13?) to make some sparks. I now hate to think what it was doing to my neighbour's TV and radio reception! At the time I was too ignorant to think about such things.
#3 |
LOL,
It sounds like a relay with its coil powered via the normaly closed contact.. Feeding a transformer...connect a capacitor across the coil to slug the relay. ![]() The free added extra is a pile of noise created by the back EMF and magnetic interference... great for testing your amp for pick up.. <<<watch it melt down with instability..LOLThe sub woofer is probably better you can test your tubes for microphonics at the same time..Thump crackle, thump burrr, thump clang, ![]() I think you will find its not a sort of AC its a sort of square wave chopped DC + a pile of Hash.. (ie you cannot transform DC ..yes you can if you chop it into a square wave or switch it on and off)Regards M. Gregg
What is the sound of one hand clapping? Last edited by M Gregg; 21st September 2012 at 09:51 AM. |
#4 |
The Flintstone SMPS !!
A couple of motors connected and you got a smaller unit then the woofer. |
#5 |
Flintstones LOL
The mechanical action makes me think of a hydraulic ram for some reason. OP, it isn't really useful. The reason is that the same thing can be done far more efficiently without moving parts... well, the only moving parts are electrons in a conductor. But I think your tabletop experimenting is great.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#6 |
This is not a new idea.....this is exactly how car radios made in the 1940's and 1950's made 300 volts from a 6 volt car battery to power the vacuum tubes. The really old tube testers had sockets to test the "vibrator".
My first car had a pair of 6V6's operating from a 6 volt car battery. It was a 1949 Plymouth. Vibrator Power Supplies
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#7 |
well it generates over 100 volts with just one double A battery because when i hook a light bulb up to it the bulb lights up easily!
and yes i think its a chopped square wave so im just using the subwoofer as a fast on and off switch and i think i can convert the high voltage back down to high current and lower voltage somehow but i dont want to blow something up with that LOL but it could be useful in powering something at the beach with some little puny batteries lol very very good lifetime of these batteries actually! after an hour of running powering something they aren't even warm! they're still stone cold! it's really cool! |
#8 |
There are better methods, but it is fun to play.
#9 |
DC to AC inverters are dirt cheap right now.....
#10 |
Hey realflow it is sounding like you have invented the perfect perpetual energy converter .. Well done . Now would be a good time to get paranoid as the oil companys will be wanting a quiet chat with you alone in a secluded woods ..
| Need schematic for AC to DC converter (12V AC in to 12-18V DC out) | maurycy | Power Supplies | 6 | 6th January 2012 08:27 PM |
| Mesure DC in AC outlets Cant find what is making noise in my AC 30CCX Help!!! !!! | Ulisez | Power Supplies | 13 | 23rd November 2010 06:42 AM |
| 18V AC+ 12V AC to +/-15V DC?? | Elbert | Power Supplies | 8 | 24th July 2010 06:10 PM |
| heater voltage: why ac, and not dc? | alex278 | Tubes / Valves | 18 | 7th October 2005 12:21 PM |
| Oil Capacitor DC vs. AC Voltage Rating | valveitude | Tubes / Valves | 2 | 10th June 2005 11:45 PM |
