Old 20th September 2012, 02:38 PM   #1
alecu7 is offline alecu7  Canada
Default LED bias for 6N1P driver
Hi all,
All schematics I could find about LED bias on a typical SET amplifier 6N1P + KT88 (a.k.a. Abdellah) show 2 red LEDs in series, drop in volatge being ~1.66V / LED.
My question is could I use a blue LED from Vishay part number TLHB4400 instead of 2 red LEDs? The spec shows 3.9V@20mA (from the graph ~3.5V@4mA). I know blue LEDs are different internally than red LEDs but for this application will this be ok?
Thanks,
Alex
Old 20th September 2012, 05:10 PM   #2
The trick is to find a suitable voltage drop with the smallest resistance possible.
Cheap red leds seems to have the lowest resistans/voltage ratio.
Ultra bright leds and blue ones is less good because of higher internal resistance.
Voltagedrop depends on the current so check manufacturers spec sheet to find a suitable led.
Old 20th September 2012, 11:51 PM   #3
tomchr is offline tomchr  United States
tomchr's Avatar
What he said!
You can find the dynamic resistance of the LED by looking in the datasheet. The dynamic resistance is the slope of tangent to the forward voltage vs forward current curve at the chosen operating current.
~Tom
21st Century Maida Regulator, Universal Filament Regulator, 300B Driver PCBs, and more...
Neurochrome : : Audio - http://www.neurochrome.com/audio - Engineering : : Done : : Right
Old 21st September 2012, 03:19 AM   #4
From the datasheet the slope looks pretty much constant. I will try it.
Thanks,
Alex
LED bias with gNFB mashaffer Tubes / Valves 1 21st December 2010 11:01 PM
LED cathode bias - how to pick LED? sharpi31 Tubes / Valves 32 9th November 2010 08:55 AM
LED bias indicator scottw Tubes / Valves 6 6th December 2007 11:19 AM
LED Bias Modifications dsavitsk Tubes / Valves 30 9th September 2007 06:55 PM
grid LED bias? fred76 Tubes / Valves 13 4th August 2006 12:00 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
