what to do with a 12W 600ohm to 4/8 ohm output transformer? - diyAudio
Old 18th September 2012, 07:57 PM   #1
Default what to do with a 12W 600ohm to 4/8 ohm output transformer?
Hey guys,
I recently ripped apart an old build, and now have a hammond 119DA spare... i was using it in an SE 1/4 watt application where it wasn't really used to its full potential, so my question is, what could i do with it? what tubes could i use it with? and what configuration?
Old 18th September 2012, 08:10 PM   #2
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
OTL with impedance matching transformer output.
The Devil is not so terrible as his math model is!
Old 18th September 2012, 09:29 PM   #3
Hello,
The “Ear” is a headphone amplifier made by MapleTree Audio, it uses that transformer. The amplifier output is a 12B4A cathode follower with a 30uf capacitor followed by that Hammond transformer.
I built a bootleg copy. it works well!
DT
Old 18th September 2012, 09:43 PM   #4
OTL with impedance matching was what i was thinking, I think il leave the headphone amp. i'd rather have 2 channels, for a low power HiFi, 1 channel is usable, or even a Mic pre maybe...
Any schematics for anything?
Old 18th September 2012, 11:40 PM   #5
another twisted way to use this transformer is to tie the output in series to the negative feedback network and use the primary as a DI output (to pins 2&3 on a xlr connection)
if you need less voltage on the xlr, use the 4 ohm tap on the primary. If you still need more build an "O" type attenuator on the 600 ohm secondary (xlr side).
Old 18th September 2012, 11:47 PM   #6
Hmm, I think i would like to use as much of the 12 watt potential as i can, but i cant see an easy way of doing that. im thinking a push pull output between 2 cathode followers? but then whats an ideal output, 12BH7?
The idea of using it the other way for a line out is interesting, could do a better job at speaker emulation than a dummy load.
Old 20th September 2012, 02:04 AM   #7
Fenris is offline Fenris  United States
You could try something like I did here:
New amp: 13DE7 SE hybrid
Listen to the music through the stereo, not the stereo through the music.
Old 20th September 2012, 07:29 AM   #8
Good idea, a MOSFET output would be much more efficient, and i think i have a few IRF MOSFETs laying around, though i may try with a lower voltage and a pushpull configuration of N and P type MOSFETs, at +/- 40v with an ECC82 to drive it.
Old 20th September 2012, 09:40 PM   #9
pilovis is offline pilovis  Italy
The audio transformer is 600-800/8 ohm 10W (600 ohm suggested)
L = 4-5 turns diam.0.5 mm around the 82 ohm 2W resistor.
Supply voltage: min 50Vcc - max 110Vcc (90V suggested)
Heaters voltage: min 24Vac/Vcc - Max 29Vac/Vcc (27V suggested)
Cathode resistors = 39 ohm 2W
Note: a bypass capacitance of 470uF 50V could be added in parallel to the cathode resistor of each tube.
Power supply for 50Vcc.
Old 20th September 2012, 10:28 PM   #10
Better do a PP with PL84's, at about 250 anode voltage.
5k:8 ohm vs. 10k:16 ohm output transformer. What is the difference? Austin Translation Tubes / Valves 109 24th July 2012 01:56 AM
WTB 4x Mills 12W -390 Ohm ASAP!! limono Swap Meet 3 20th May 2011 06:34 AM
2300 ohm vs 5000 ohm output trans question speakerfritz Tubes / Valves 4 2nd October 2010 10:17 PM
V-out DAC output transformers! 600:600ohm. Perfect for CS4397/8 gripracer Swap Meet 6 23rd July 2010 12:36 AM
How to connect 62 ohm headphone to 8 ohm output Sunsun22 Headphone Systems 15 16th June 2007 01:29 PM
Copyright ©1999-2017 diyAudio
