Hello,
I've found one chassis of this nice amp. It's version with 4xEL500, 2xECF80 and 6xECC808. I need help with schematics and data for output transformers. Thanks, Dragan |
#2 |
A quick google search turns up this:
Telewatt Stereo-Nova VS-71 M ECC83 Amplifier Klein & Hummel; Looks like you can get the schematic there if you're a member (whatever that involves).
21st Century Maida Regulator, Universal Filament Regulator, 300B Driver PCBs, and more... Neurochrome : : Audio - http://www.neurochrome.com/audio - Engineering : : Done : : Right |
#3 |
I'm member, but I can't download it ...
#4 |
Maybee this can help You (second chanell is the same):
#5 |
Thanks a lot for schematics Davorin. I have slightly different version with 3 ECC808 per channel.
Pozdrav! |
#6 |
Hello ,
look at the datasheets , the ECC808 is electrical the same tube like ECC83 but with a different pinout and better data for hum and hiss and channel separation . Regards , Alexander .
No reason to get excited : Jimi Hendrix . Last edited by RE 604; 20th September 2012 at 07:12 PM. |
