Yamamoto 09S 300B SE Amp Problem Yamamoto 09S 300B SE Amp Problem - Page 8 - diyAudio
Old 11th January 2013, 12:35 AM   #71
Alexsk is offline Alexsk  Canada
20hz phase
sorry for the "ipad" camera quality
Old 13th January 2013, 08:18 AM   #72
fonnesbek is offline fonnesbek  Denmark
I have now completed the second amp
I have done a little listening and I think it sounds great, I think it is kind of problematic judging the quality of something you have build yourself !!!
But for now I think it sounds better then my Firstwatt F5, a bit darker which I think is because for the roll off -3db at 20KHz.
But I think the resolution is better and all the micro details are much clearer.
And overall the music is more alive.
I have included a few measurements, all done at 1V rms out.
Old 13th January 2013, 09:49 AM   #73
euro21 is offline euro21  Hungary
IMHO relevant measurements (THD, FFT, and transfer characteristics) at (for example) 8 Ohm resistive load:
2.73V RMS 1W
5.66V RMS 4W
8.00V RMS 8W
Old 13th January 2013, 02:14 PM   #74
2.73V RMS 1W
5.66V RMS 4W
8.00V RMS 8W
Are ypu trying to say that mesurments at 2.73 vrms are relevant and at 3vrms (1.125w in 8 ohm) are uninformative ? May I ask why ?
Old 13th January 2013, 03:14 PM   #75
Jogi is offline Jogi  Germany
Congrats for the working amps! Sometimes it takes a while to sort out the bugs which seem to sneak in even with greatest care...
The rolloff starts already at 8khz, interesting that a little THD peak is at the exact frequency.
Also interesting that the 310a/300B combo gives about the same rolloff and has a reputation for a little dark sounding; as Alex pointed out with basically the same circuit.
But, as said, it still will be much better sounding than 6sn7 or 6sl7 driver.
Good thing is that you can listen to it and change to different circuit in very little time and compare.
I always wanted to supply the screen with a Salas SSHV shunt reg, but space is too tight and heat would be difficult to disperse. The screen supply seems to be very critical for sound, should be very stable and clean.
Old 13th January 2013, 06:03 PM   #76
One more thing (of course its just a suggestion, nothing more): do not rush to make any changes, make sure that all operating points are correct, everything works as expected and play it for at list few month, let it settled down, get very familiar with it and try to find out what exactly you like and dislike. After that if you feel like experimenting, try high current driver.
Good luck!
Old 13th January 2013, 06:19 PM   #77
3V RMS ???
Fonnesbek measuring at 1V RMS!
This 1V (0.125W) and -41.62dB THDN (about 1% distortion ? ) are incredible.
Or worst case 300B damaged.
Old 13th January 2013, 07:32 PM   #78
Sorry for the confusion, I did the measurements uncalibrated, just redid them at 1W 2.73V into 8 Ohm and at 4W 5.66V.
At 1W THD+N is -42dB
At 4W THD+N if -34dB
Hope these numbers make more sense ?
Old 13th January 2013, 07:38 PM   #79
3V RMS ???
yes, you are righ, -40db at 1vrms is too much, even at 10khz (is it 10k?)
Also HF attenuation is too high.
Fonnesbek: what transformers ar you using ? Also what are the distortion figures at 1khz ?
Old 13th January 2013, 08:02 PM   #80
found my notes on A09s mode:
Frequency hz --- 3v rms into 8r --- 7.5 vrms into 8r
20. -42 n/a
30. -48.5. -31
40. -46.5 -33
50. -45 -34
100 -44 - 35
1k. - 41 -34.5
10k. -?? -30
16k. -38 -30
20k. -37 -28
HTH
Yamamoto 09S 300B SE Amp ProblemHide this!Advertise here!
Yamamoto A-09s fonnesbek Tubes / Valves 11 22nd November 2012 09:12 AM
300B SE amp: One more one Yvesm Tubes / Valves 15 22nd February 2010 05:12 PM
* 35 watt * 300B SE = super 300B + Class A2 rick57 Tubes / Valves 4 13th July 2005 04:18 PM
My 300b SE amp purer Tubes / Valves 2 28th December 2002 04:25 AM
Copyright ©1999-2017 diyAudio
