Hi all,
As you can see I am quite new to this board. I recently completed a 6V6 amp based on one of Poindexter's designs (I have attached a picture). I am very pleased with the sound, but am going to upgrade a few components to see (and hopefully hear) any effects. I am going to start with the coupling caps - I used sprague 'orange drops' in this one, but recently purchased some Mundorf silver supremes, which Poindexter recommended in his implementation guide. My question is, I have two values I can use, 0.33uf which is in the original plan, or 0.47uf. I am wondering if the higher value will bring any benefit at all? I ask because I read somewhere that higher coupling values may improve the bass response to a point. Thanks for your input. |
#2 |
diyAudio Chief Moderator
Hi and welcome to the forums. There is no picture to be seen, the attachments interface needs press ''go advanced'' under the posting window, then roll down. Maybe it was too big a file, see max allowed near each file type on the attachments interface. Maybe you need to re-size.
![]() P.S. As for your question, many can elaborate and Poinz is a member too. You need attach or link the schematic if its free-share for defining such questions though. |
#3 |
Picture resend - it appears to be within size guidelines:
CDT |
#4 |
Nice organic box. If in your shoes I would go with the 0.33uF as recommended because on 100K grid resistors 0.47uF will not make any big response difference, only it will be bulkier, plus this is a design with a detailed parts guide as I read so its better you follow Poindexter's values exactly since he had blended his tone with those materials and values carefully. Only keep oil carrying Mundorfs as much away you can from heat sources. Also try Tungsol reissue 6V6s at a point maybe.
#5 |
A circuit diagram would be good.
You could try the bigger caps as an experiment. If it sounds like a chugging motorboat, switch it off immediately and revert to the smaller caps. If not, listen and see what you think. Something with a range of instruments and heavy bass, with loud bits. The chances are that the caps are correctly specified to fit in with the rest of the design. No larger than necessary is usually best for coupling to the output stage. The bass roll-off should have been optimised with a particular output transformer in mind. If your transformer is capable of supporting bass lower than the design expected, it will be possible to modify it. However, the coupling caps are just one frequency-controlling element amongst several. Basically, you should ensure that the combination of output valves, transformer and speakers doesn't get lower bass than it can handle without causing unacceptable distortion and possible oscillation. |
#6 |
Creative casing. The high pass (filtering low frequencies) is normally a function of the output transformer, as the most delimiting unit in the amplifier. Coupling caps can be too small so they come in to play, as can be catode bypass caps. This is not a good practice as it will bundle phase shift with the OPT (output trannie). Here I've put some theory behind the calcultation of the bypass cap which I unfortunately gave the name of Low Pass Filter, what should have been HPF.
jaap |
| Bell 2420 tube amplifier. Bias question. 6v6 push pull | The Donk! | Tubes / Valves | 5 | 30th May 2013 09:40 AM |
| 6V6/12AX7 Project Question/Help | Skitch72 | Tubes / Valves | 4 | 27th February 2011 09:25 PM |
| 6v6 PP biasing question | mor2bz | Tubes / Valves | 1 | 24th November 2010 06:46 PM |
| Power Transformer for 6V6 SE Amp Question | zxx123 | Tubes / Valves | 3 | 25th January 2008 02:06 PM |
| new 6V6 amp | sorenj07 | Tubes / Valves | 7 | 11th September 2007 02:09 PM |
