Can I build a screen reg. with IXYS 10M45? - Page 2 - diyAudio
Old 18th September 2012, 08:43 PM   #11
Hello,
This has me scratching both head and back side at the same time.
Triode strapped both the anode current and screen current sum and act in parallel. As you say they remain proportionate to each other over the range of values. If the valve is connected as a pentode with a constant voltage on the screen and changing anode voltage, from the load point of view, I do not see anode and screen currents summing or remaining protonate to each other over the range of values.
We often place a CCS at the plate of a triode for parameter restriction including a more constant Mu and reduced distortion. When we do this to a pentode screen we disconnect the summation and proportionate performance of a triode strapped pentode.
If we plot Mu vs Anode Current what do we get;
Triode curves, likely not?
Pentode curves, more likely to look like this?
Tetrode curves, with a funny bump?
Some new kind of Ultra-Linear curves with an odd new flavor series of harmonics?
DT
IXYS 10M45 CCS IC question zobsky Tubes / Valves 19 26th July 2008 09:15 PM
Help with e180f and ixys current reg duderduderini Tubes / Valves 4 20th February 2008 01:51 AM
Red Light District Amp Screen Reg mach1 Tubes / Valves 20 28th February 2007 10:37 PM
IXYS 10M45 chip CCS Alastair E Tubes / Valves 3 31st December 2006 01:45 PM
Wanted IXYS 10M45 guglielmope Swap Meet 0 29th June 2006 09:10 AM
Copyright 1999-2017 diyAudio
