Would using a 16ohm speaker damage my SE output transformers?
Old 16th September 2012, 03:22 PM   #11
Pano is offline Pano  United States
Pano's Avatar
Originally Posted by flatheadmurre View Post
Enough so you get the power needed for listening !
What I really meant was - "If it is not advisable to run a tube output unloaded, how much load do you need?" Would 100 or 600 ohms on an 8 ohm tap be enough? If yes, then 16 ohm speakers on a 4 ohm tap should be just fine, right?
Take the Speaker Voltage Test!
Old 16th September 2012, 03:29 PM   #12
kevinkr's Avatar
I've not had problems with loads of up to 100 ohms, but would not recommend running much more than 16 ohms on 4 ohm taps as this is unknown territory to me..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 16th September 2012, 03:53 PM   #13
flatheadmurre is offline flatheadmurre  Sweden
Itīs the reflected load on the tube thatīs interesting, not what load you have on which winding.
Somewhere a long the line the tube starts misbehaving with a to light load, then you have reached the limit.
As long as there is enough load on the transformer to prevent voltage building up creating shorts there shouldnīt be a problem ??
Old 16th September 2012, 04:14 PM   #14
Vinylsavor is offline Vinylsavor  Germany
Vinylsavor's Avatar
Hi!
The amp will not get destroyed if you run it with a 16 Ohm speaker unless it is extremely poor designed. In that case it could also be destroyed with a 4 Ohm speaker if run hard. Keep in mind that the speaker impedance varies over a wide range for most speakers. Even a 4 Ohm speaker can have impedance peaks well above 30 Ohms in the bass region.
In my experience many speakers benefit when they are being driven from a lower impedance. As suggested you can experiement with resistors in parallel. But keep in mind that a big portion of the power will then get burned in the resistor. A resistor will linearize the speaker impedance. This may or may not yield a sound improvement. Experiment and use what works best
Thomas
http://vinylsavor.blogspot.com/
Old 17th September 2012, 12:55 AM   #15
wa2ise is offline wa2ise  United States
wa2ise's Avatar
Headphones are sensitive devices and what a speaker eat chew and spit out will kill the headphones.
And it won't do your ears any good either. Do be careful you don't have the volume up too high when you connect your headphones.
Old 17th September 2012, 02:40 AM   #16
Francois G is offline Francois G  United States
Kevin,
I'm surprized at your reply.
Is it simply your personal "unexplored territory" that made you say that or do you know of theoretical reasons why it may be harmful to drive more than 16 Ohms from a 4 Ohm transformer tap?
The question was about safety, not fidelity. It is reflected load that matters, is it not?
Francois
Old 17th September 2012, 05:47 AM   #17
kevinkr's Avatar
Originally Posted by Francois G View Post
Kevin,
Francois
Perhaps you are reading too much into my reply.. In the case of a zero feedback amplifier there is a point where effectively even though there is "something" connected to the secondary it no longer constitutes an effective load, and under fault conditions there is probably greater potential for excessive voltage to be developed across the primary in the event the output tube is driven into hard clipping or cut off. (flyback) This is probably far higher than the numbers discussed here, but without knowing anything about the amplifier I can't put a hard fast number on what is ok and what isn't.
Without scope, the specific amplifier and load on the bench I can't reasonably state what maximum value of load might be safe under worst case circumstances. All I'm actually saying is "proceed with caution" and I am just one voice amongst many here.
Old 17th September 2012, 02:24 PM   #18
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
I tried it and it works perfectly fine with 16 ohm speakers and 25 ohm headphones on the 4 ohm output. It is off triode-strapped EL84's. Thank you kevinkr and everyone else.
Old 17th September 2012, 03:12 PM   #19
I just tried my 600 ohm headphones and it works too!
Old 18th September 2012, 08:59 AM   #20
palmas is offline palmas  Portugal
Not a problem even to let the the speaker unconnected, at least in all my designs and constructions!
I just use good quality transformers and use a fixed load of 220Ohm inside the amp.
I test run them unloaded to see if there is any problem and there never was...
Also run them with 2Ohm and appart from the small reducing in frequency response, never had a problem.
Would using a 16ohm speaker damage my SE output transformers?Hide this!Advertise here!
Cheap SE output transformers gja Tubes / Valves 97 30th October 2015 11:57 AM
SE Output transformers MartinV56 Tubes / Valves 4 2nd October 2009 07:39 AM
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
SE Output Transformers DVDHack Tubes / Valves 32 19th January 2004 10:52 AM
A new source for SE output transformers? G Tubes / Valves 12 26th August 2003 09:11 PM
