Old 16th September 2012, 05:36 PM   #11
richwalters's Avatar
Rule of thumb...I aim for all voltages in a cathode follower to be a third each of the B+. My schematic I commonly use.
.....in concertina I don't bother with split cathode resistor.
solong it's DC bias strapped to preceeding stage which is in control. I've always assumed since the stage operates with fantastic neg feedback, the concertina distortion is already extremely low or an be ignored if Correctly operated..
The B+ is approx 360V which is off the pic.
richy
Old 16th September 2012, 07:24 PM   #12
nlinus is offline nlinus  Sweden
nlinus's Avatar
Well, that's not exactly the case with my current values. A B+ of 300V and anode/cathode resistors on 3.4k each.
At 15mA, that would result in a Vak (voltage drop anode to cathode) of 198V.
I don't know if I misinterpreted the values in the datasheet.
Ua is set to 200V for triode mode.
One of my other projects: Svarthålet Racing
Old 16th September 2012, 08:17 PM   #13
C3g is a high gm pentode.. your drawing shows g1 to cathode and you are using the screen as signal input: Correct ? That changes my equational picture somewhat.
Old 16th September 2012, 09:17 PM   #14
nlinus's Avatar
It shows (or at least it should show) g2 to anode, g3 to cathode and g1 (not marked) as signal input.
Hiraga's Improved Concertina Phase Splitter Tubologic Tubes / Valves 16 16th April 2012 07:41 PM
Need help on the working of this LED inverter circuit voltwomen Everything Else 1 3rd October 2011 06:17 PM
LED cathode bias - how to pick LED? sharpi31 Tubes / Valves 32 9th November 2010 08:55 AM
Phase inverter ThSpeakerDude88 Tubes / Valves 37 29th August 2007 03:15 PM
6C8G phase inverter engels Tubes / Valves 4 4th February 2007 06:01 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
