HT power supply high?
Old 14th September 2012, 03:01 PM   #11
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Originally Posted by palmas View Post
What gain would you like to have?
Around 10 db max.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 14th September 2012, 03:24 PM   #12
palmas is offline palmas  Portugal
something like this?
Old 15th September 2012, 07:59 AM   #13
Nuuk's Avatar
Palmas, I'm nowhere near competent enough to assess your design. I was thinking more of being able to adapt the existing circuit to have lower gain, rather than building a complete new one.
Old 15th September 2012, 09:30 AM   #14
DF96 is offline DF96  England
In that circuit the gain is more or less set by the valve. To get different gain you need a different valve or a different circuit. A different valve might mean circuit changes anyway. It is only circuits with significant negative feedback which can be simply altered to get different gain. Even then, less gain means higher loop gain which can mean instability.
Old 15th September 2012, 09:52 AM   #15
Nuuk's Avatar
Thanks DF96. I'll leave that one well alone then, and think about building a new one using the same power supply (which is in a separate box).
HT power supply high?Hide this!Advertise here!
Opinions on Power Supply HT Ripple Current techbiker Power Supplies 11 31st January 2012 03:08 AM
High current Jung power supply with HT regulator pcb chris found Power Supplies 0 13th April 2011 07:25 PM
Power supply:Universal AC input/ Full range,High Efficiency, and High reliability hang Vendor's Bazaar 12 24th July 2009 03:46 AM
high frequency high voltage power supply... moray james Planars & Exotics 6 23rd July 2008 07:57 PM
