Hi All,
I am making Eli Duttman's 12B4 Linestage. I have 120 to 140 volts to the CCS, depending on the first cap size. Problem is, I am dropping to 45-50 volts in the CCS (with tube in place.) Same result for either cascaded DN2540 or Bottlhead C4S. If I replace the CCS with 6K plate resistor, I get about the same result. I can't figure out what is wrong. Why would the CCS drop so much voltage? I'm going crazy trying to figure this out. It should be such a simple circuit - and I did have it working before I redid my preamp. Any suggestions? TIA Doug Rice |
#2 |
tube is dictating it's voltage from K to A , when biased per schematic
CCS will adjust it's working to tube's dictate it's already written at anode - 90V/20mA
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#3 |
Cathode voltage?
500R * 20mA = 10V |
#4 |
If you biased the tube to pass 20mA at idle and use a 6k plate resistor, you get a voltage drop across the resistor equal to 6000*0.02 = 120V. To get 90V on the plate, you need to have a B+ of 210V. The ccs will have a similar voltage drop. No free lunch.
#5 |
Thanks all. I guess I misunderstood Eli's previous posts about the power. I thought he was feeding about 125 volts into the CCS. Ikoflexer - I learned something new today - CCS drops the same voltage as a resistor. Thanks!
Time to go bump up the b+! Doug |
#6 |
More accurate to say that with a given grid bias and given anode current a valve will have the same anode voltage.
#7 |
Exactly- if you set the B+ to 150V (or 140V, for that matter), you'll still have 90V at the plate with a CCS.
If there's a sucker born every minute, where do the rest of them come from? |
#8 |
It's a mistake.
CCS pumping definite current to the anode. Cathode current on cathode resistor create bias voltage. Bias v. and anode current define operating point, thus define anode voltage (over cathode). B+ minus anode voltage is CCS dropping voltage. Cascode (DN2540) CCS happy with 10-20 V drop! |
#9 |
OOOH my head hurts.
Re-configured the trafo for 220 V AC output instead of 115 V. Getting a B+ of about 165 V with FWB - is it low due to 9K bleeder?? Anyway, still have about 165 V (under load) going into CCS and about 53 V on plate. Dropping about 3V across R-bias (180 ohm - so, about 17 mA current.) Yet another dumb question: I don't have grids connected to anything yet. Trying to get the right voltage first. Is that OK? Measured cathode V at +10 V above ground. I am using DC for heaters, with 500 ohm cathode resistor with no bypass cap. Jeez. I can usually follow a schematic, but this is confusing. Thanks to all. Doug Last edited by Doug R; 13th September 2012 at 09:37 PM. |
#10 |
The grid must be connected to something, otherwise nothing will work. No point in measuring anything or testing anything with the grid floating. No point in showing us a circuit which you have not built.
| CCS for 12B4 linestage | 240z4u | Tubes / Valves | 8 | 24th October 2007 10:11 PM |
| 12b4 vs. aikido linestage | Klimon | Tubes / Valves | 2 | 14th August 2007 11:38 AM |
| 12B4-A Linestage | sorenj07 | Tubes / Valves | 51 | 12th February 2007 02:29 AM |
| low frequency oscillation in 12B4 linestage | Original Burnedfingers | Tubes / Valves | 8 | 11th December 2005 12:27 AM |
| 12B4 versus 6S4 for linestage | rcavictim | Tubes / Valves | 4 | 4th December 2005 08:22 AM |
