Transformer orientation and suggestions.
Old 13th September 2012, 10:25 AM   #11
palmas is offline palmas  Portugal
Just another thing: why use PCB? point-to-point wiring is so much better!
Old 13th September 2012, 10:41 AM   #12
nanchangbob is offline nanchangbob  United States
nanchangbob's Avatar
Already have the PCB's and this is my first amp build. I thought it would make it easier.
A great day to listen to music.
Old 6th November 2016, 07:08 PM   #13
engelheimer is offline engelheimer  United States
Default 4 in 1 tool
Most of my work is from DIYer's guitars and amps with issues from pickup/xfrmr polarity issues. Here is one of my builds, that defies explanation.
Will spill the beans with this simple tool. Power the amp up and czech the +/- of the xfrmrs.
Old 7th November 2016, 01:15 AM   #14
Trajan is offline Trajan  United States
Consider the weight distribution as well if you can. Nothing leads to dropped amps like all the weight on one side.
Old 7th November 2016, 01:17 AM   #15
drlowmu is offline drlowmu  United States
Banned
I do NOT like the On-Off switch brought forward to the front, and in proximity of a Selector Switch. Avoid this !!
I like the Power Transformer tucked away in the left rear corner, as you drew it. Can you somehow locate the On-Off switch back there too?
I do NOT like the RCA input jacks in the rear vertical portion of the amp, requiring LONG wires to reach the selector and volume switches. TOO much chance for a degrade, of lowest level signals, in those long wire runs !!
I would have RCA jacks on the TOP of the amp chassis, right front corner or front middle area, so you can insert interconnects into the amp from any direction, and KEEP the lead length 2 inches or less, into the amp.
The choke, away from the power transformer is good, but do NOT let it crowd the Selector Switch, especially if its choke input, as the first filter element
Then, you have it !!
Jeff
Old 7th November 2016, 10:49 AM   #16
DF96 is offline DF96  England
Originally Posted by nanchangbob
My chassis has holes cut in the back for IE and binding posts. I rotated the back piece so I can have the amps sit as a mirror image to each other.
Bad idea, IMHO. It guarantees that the two channels cannot be identical (e.g. stray capacitance), as you can't get mirror image valves. It may look nice, but the main purpose of an audio amplifier is not to look nice but to amplify.
Transformer orientation and suggestions.Hide this!Advertise here!
Transformer orientation imnewbie Construction Tips 0 3rd August 2012 04:07 AM
Orientation of E-I core OPT and toroidal power transformer tomchr Tubes / Valves 4 27th December 2009 06:02 AM
Transformer orientation Skorpio Pass Labs 5 12th May 2006 02:25 AM
Mains transformer orientation Rocky Tubes / Valves 20 23rd November 2005 11:52 AM
EI transformer orientation ultrachrome Power Supplies 3 28th March 2005 05:11 PM
