Chinese GU50 PP - diyAudio
Old 11th September 2012, 01:50 AM   #1
Default Chinese GU50 PP
I have a GU50 PP coming from China. $286 sans tubes plus postage of $178 to Australia so still cheaper than buying the iron locally.
Any suggestions for mods?
The schematic is here
http://www.bezdz.com/images3/T30B-50-%B8%BA%D1%B9.bmp
The build quality of their other amps look good so will be interested to see what it looks like on arrival. I have already built a Se GU50 and love the sound of this tube.
Old 11th September 2012, 02:45 AM   #2
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
It is quite strange amp: UL, 420V B+, Gu-50. Most probably they used Gu-50 tubes in the amp designed around EL34.
The Devil is not so terrible as his math model is!
Old 11th September 2012, 03:38 AM   #3
Looks that way looking at their other EL34 circuits. Its all point to point wiring so easy to mod. Any suggestions? I am not a valve guru by any means but am handy with a soldering iron! Seems to be plenty of scope with the power supply voltages, perhaps a higher B+?
Old 11th September 2012, 04:13 AM   #4
Wavebourn's Avatar
No, you will fry screen grids by higher B+, and higher load impedances will be needed (different iron). I would better wait for this wonder and check how does it perform. Then try it with EL34 tubes if you have them, and compare. Gu-50 are nice pentodes, but they want twice more B+ and higher load impedance.
Old 11th September 2012, 09:09 AM   #5
palmas is offline palmas  Portugal
The 0.1uF cap seems a bit small for a 97k load and the 50k volume is a bit to low, but just my impression. The rest looks like a classic. You should try the russian GU50, they are very tough and sound beautifuly.
Old 11th September 2012, 10:39 AM   #6
You were right Wavebourne, found a very similar circuit while digging around on their site.
http://www.bezdz.com/images3/T1S-34-%20KT88.bmp
Will be interesting to see what it sounds like.
Will post pics and first impressions when it arrives.
Old 11th September 2012, 03:15 PM   #7
screen grid seeing 416 volts?
but the GU50s have a max 250volt screen grid.
operating waay over spec, are they ok with it?
Old 11th September 2012, 03:29 PM   #8
That is not a problem with russian GU50, even at 450V... never used chinese ones.
Old 11th September 2012, 03:42 PM   #9
then it shouldn't be much hassle to make a kt88 p-p Williamson style amp with 440volt, ultra linear/triode would it?
Old 11th September 2012, 03:49 PM   #10
KT88 is a different bugger, not that well built and prone to faillure
Suppo Audio -- New Chinese EL84 PP amp for CHEAP. bigjppop Tubes / Valves 431 7th February 2013 11:30 PM
PP GU50 triode strapped project FrançoisL. Tubes / Valves 63 27th July 2012 11:33 AM
Modification of a Chinese KT90 PP amplifier FYC Tubes / Valves 2 12th May 2012 10:46 AM
OPT PP for GU50 Triode ? pwan Tubes / Valves 0 13th March 2011 12:30 AM
Channel death - Chinese EL34 PP theskintman Tubes / Valves 2 10th July 2010 06:41 PM
Copyright ©1999-2017 diyAudio
