Chinese GU50 PP - Page 2 - diyAudio
Old 11th September 2012, 02:49 PM   #11
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Originally Posted by ruben alstad View Post
screen grid seeing 416 volts?
but the GU50s have a max 250volt screen grid.
operating waay over spec, are they ok with it?
In UL mode they may survive. In triode you may use up to 450 V, in pentode maximum 300V (in audio amp).
The Devil is not so terrible as his math model is!
Old 11th September 2012, 03:05 PM   #12
Originally Posted by palmas View Post
KT88 is a different bugger, not that well built and prone to faillure
sorry, i meant to make the kt88 amp use GU50s instead.
Old 11th September 2012, 03:07 PM   #13
Wavebourn's Avatar
Do you mean KT88 in this particular amp instead of Gu-50?
Yes, in such regimes they would be happier.
Old 11th September 2012, 03:30 PM   #14
it may need a new thread, but GU50s can operate on kt88 amps with a rebias?
push pull UL/triode 430/450b+ driven by 12au7 phase splitter.
this amp is going to be rebuilt anyhow, might aswell make it run on gu50s.
also the phase spliters are probably going to be replaced by either 6CG7,12bh7 or a 6sn7.
Old 11th September 2012, 03:32 PM   #15
palmas is offline palmas  Portugal
They might, but you'd have to check case by case and sockets are not exactly same size
Old 11th September 2012, 03:43 PM   #16
They might, but you'd have to check case by case and sockets are to exactly same size
gu50s use their own socket.
kt88 uses octal.
6sn7 uses octal
12au7 12bh7 and 6CG7 uses noval.
Old 11th September 2012, 03:51 PM   #17
Some idea for improvement: If the PI's tail resistor is returned to the second filter cap of the bias voltage supply, the 560k/150K divider, the following 68k resistor and the 0.1µ cap from pin 7, second tube, could be omitted. Pin 7 and the grid leak must be grounded in this instance.
This would lead to a bigger possible output voltage swing for the PI - not too bad for GU50 finals.
Best regards!
Old 11th September 2012, 03:55 PM   #18
Wavebourn's Avatar
No. I meant in this particular amp KT88 may work better than GU-50. GU-50 likes higher anode voltage and load resistance, and lower G2 voltage than KT-88.
Old 11th September 2012, 11:51 PM   #19
So I would be better off running in triode mode to increase the survival rate?
Old 12th September 2012, 12:15 AM   #20
Wavebourn's Avatar
Yes, but you will get less power than in UL mode. But it should be cleaner power.
Suppo Audio -- New Chinese EL84 PP amp for CHEAP. bigjppop Tubes / Valves 431 7th February 2013 10:30 PM
PP GU50 triode strapped project FrançoisL. Tubes / Valves 63 27th July 2012 10:33 AM
Modification of a Chinese KT90 PP amplifier FYC Tubes / Valves 2 12th May 2012 09:46 AM
OPT PP for GU50 Triode ? pwan Tubes / Valves 0 12th March 2011 11:30 PM
Channel death - Chinese EL34 PP theskintman Tubes / Valves 2 10th July 2010 05:41 PM
Copyright İ1999-2017 diyAudio
