6n14p headphone amp
6n14p headphone amp
Old 10th September 2012, 09:05 PM   #1
milosus is offline milosus  Serbia
Default 6n14p headphone amp
one question-is this amp will be suitable for drive 32ohm load? like they wrote.
Thank you
Old 10th September 2012, 09:52 PM   #2
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
6n14p headphone amp
It depends on voltage swing needed on 32 Ohm load, and maximal distortions you can tolerate. First, you should find current swing of cathode current needed to drive your load to needed voltage swing. Then, looking at curves what kind of grid to cathode voltage swing is needed for such current swing, and how linear will be output. Also, check if triodes of the tube on such current and voltage as drawn on schematic mean power dissipation below SOA, or you risk to fry the tube.
Then you have to calculate impedance of coupling capacitor (100 uF on schematic) in respect to impedance of the load (32 Ohm) and decide if roll-off on the lowest frequency (say 20 Hz) satisfies you.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
6n14p headphone ampHide this!Advertise here!
ECC84/6N14P for audio Ipanema Tubes / Valves 20 15th September 2017 12:52 PM
2x Gain pure op-amp headphone amp idea Dxvideo Headphone Systems 31 6th August 2017 05:09 PM
My new el34 + 12ax7 VCT amp. (Need Ideas For my first headphone vacuum tube amp Too~) briansune Tubes / Valves 10 12th July 2013 05:33 PM
Tube amp OPT for Headphone Amp? (impedance matching question) rongon Tubes / Valves 21 3rd January 2012 04:20 AM
What to do with a 6N14P/ECC84 Cookj Tubes / Valves 0 31st March 2011 04:14 PM
