I was wanting to know the best way to measure cathode current,would it be possible to insert a small value cathode resistor,and measure bias current,much like other Dynaco curcuits?
#2 |
I assembled this amplifier, its very good but quite hard to stabilize.
Having debugged it, I would suggest to do the following: 1) Install separate BIAS pots. 2) Install 10 Ohm cathode resistors in order to measure idle current. 3) Lift fake center tap of filament winding (2 x 100 Ohm resistors) to about 30V. 4) Install trim pot instead of fixed NFB resistor. I've got over 60W with pair of 6550/KT88/KT120 (tested all 3 types of tubes), THD at 1KHz was something 0.15% - 0.25% for power up to 50W. Pictures of breadboard PCB build attached. |
#3 |
Nice juicy fat toroid in pic: who wound it ?
#4 |
There are many factories in Eastern Europe and Germany which can wind toroids up to your specification. Toroid on picture is audio output type, you have to submit technical specification incl. winding layout to get one.
| Modifying the classic Williamson | grungeman91 | Tubes / Valves | 45 | 5th March 2011 09:55 PM |
| Looking for a Williamson squematics | burtcheca | Tubes / Valves | 7 | 3rd July 2010 11:20 AM |
| Another Williamson | floyd carter | Tubes / Valves | 3 | 20th February 2010 02:48 AM |
| low-biasing or high biasing in Class-AB amps | Workhorse | Solid State | 124 | 18th October 2005 04:45 AM |
