Phase splitting transformer design
Hi!
How should be winded a good Phase splitting transformer? 1. Bifilar mode, but with a center tap? (Like e.g. EDCOR's XSM10K:10K) Some people says its works, but some says it is not good. 2. In a "classical" sectioning way, like e.g. 3 section of prim. and 2 section of sec. Greets: Tyimo |
i have a suspicion that having several vertical sections with bifillar winding will even be better....dual section bobbins are available, but they can be made into 4 vertical sections.....
In my experience you are right Tony. A while back I was thinking of winding some output transformers using the Pi winding technique. To prove the idea I wound a center tapped anode choke for the 7N7 drivers in my 807ish amp (5B-255M). I used a pretty small C core transformer that came from a current injection rig. The first wind was a dismal failure, I just used normal interleaving. The max frequency was poor due to interwinding capacitance. The second try was split bobbin in two halves also using normal interleaving, this was better but I wanted more. The last try used a bobbin split into six vertical sections, each section had five layers. This choke was nearly perfect and I was quite pleased with it. As a phase splitting tranny it also works very well. The only trouble was I didn't write anything down or take any photos during the wind up. Doh. So I only have one and the likelyhood of making another one the same is slim. I will have a rummage in the junk box and take a photo of it if anyone is interested. Another good thing about this winding method is that although it takes a bit of time to make the bobbin the sections are narrow and there is no need for neatly wound layers.
Cheers Matt. |
Hi Tony!
Connecting the primaries in series and the sec. in parallel? Do you recommend the Pi - bifilar winding as a good counter to the capacity problems of the bifilar winding technique? Greets: Tyimo |
Hi Matt!
Greets: Tyimo |
O.K. Thanks!
How to split the bobbin into 4 vertical section? What is the best way? I have only normal bobbin or a simple split bobbin ( 2 section) Is there any trick? Tyimo |
yes, the 2 section bobbin can be converted to 4 section by using spacers that can be removed for winding, make sure to put in a permanent spacer made from thick plastic formed to fit...
I can tell from first hand experience that Edcor XSM15k:15k does NOT work well as a phase splitter. They measure fine with one end of the secondary grounded but but the frequency response is completely devastated if the CT is grounded instead.
Thanks Tony! I will try it.
greets: Tyimo |
| All times are GMT. The time now is 06:57 AM. |
vBulletin Optimisation provided by
vB Optimise (Pro) -
vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
