Old 9th September 2012, 07:26 AM   #1
h00hbt's Avatar
Default Red plate KT88
Hi
I have a quad of GEC KT88īs that show red plates when I bias them at 50mv. If I bias down to 43mv they are fine, sound great. I also have a quad of TT21īs and they are the same, have to be just over 40mv.
When I use newly produced KT88īs like Penta or EH I can bias them ut to 50mv without any red plates.
Are GECīs or the older tubes more sensitive or vice verca? My amp says that the OP tubes should be biased at 50mv.
Any ideas?.......
Cheers
/H
Old 9th September 2012, 08:53 AM   #2
artosalo's Avatar
What do you mean with "50 mV" ? How do you measure this ?
What is the anode voltage and current in case the plates are red ?
Old 9th September 2012, 09:30 AM   #3
Tony is offline Tony  Philippines
Tony's Avatar
what is your plate voltage at 50mv bias, can i assume that the cathode resistor is 1ohm and so cathode current is 50mA?
Old 9th September 2012, 10:06 AM   #4
h00hbt's Avatar
Hi Thank you both for answering.
Well I have a 1 ohm cathode resistor, thatīs right. The amp has a fixed bias, so I can adjust the bias. I measure from pin 8 (cathode) to ground. The schematics say to adjust for 60mv. B+ is 470V, havnīt measured the actuall plate voltage. OPX are 4K. This is a PP UL amp.
Cheers
/H
Old 9th September 2012, 10:19 AM   #5
Tony's Avatar
at a bias of 60mA and 450 volts plate, your tube dissipates 27 watts.....at 43ma 19 watts...if they sound fine with this bias, i see no point aiming for 60mA, your tube will live a happy longer life this way...
Old 9th September 2012, 03:45 PM   #6
h00hbt's Avatar
Yes, they sound absolutly fantastic at 43mv. I was just wondering why both the old KT88 and TT21 take a lower setting at 40+mv and newer tubes can cope with 60mv without getting red plates.
Cheers
/H
Old 9th September 2012, 05:14 PM   #7
richwalters's Avatar
Bias at 50mA per tube at 470V+ is a dream run come true for KT88's.....red plates.. I question if they are really KT88's ? You suggest ~27W dissipation.....6L6 can swallow that. .....Measurements correct ?
I've been running KT88's at 580V at 60mA (~35W diss) and then one will see a hint of cherry red. This may appear to be a hammering; but I've got alot of older designs that suggested KT88's are capable of even harder running.
richy
Old 9th September 2012, 05:35 PM   #8
h00hbt's Avatar
richy
Of course they are KT88īs and also TT21īs. The TT21 could take more plate voltage than KT88īs and still they cherry at 50mv cathode bias. These tubes where true NOS, never used and from sealed boxes.....
/H
Old 9th September 2012, 10:42 PM   #9
Tony's Avatar
that's strange, i heard the opposite with new production tubes.....but i can not argue with your results...
you can pm Jim Mcshane maybe he has an explanation...
Old 10th September 2012, 12:05 AM   #10
Zekk is offline Zekk  Singapore
My TT21 have 550v at plate > 57v bias > 680ohms > 84mA > 41watts.
Sounds full bloom and no red plate nor hum
But... it's hot! Am thinking designing a heat sink attached to metal base of tube.
Good Luck to you.
Zekk
Genalex KT88 Plate Dissipation Question Loren42 Tubes / Valves 7 28th April 2011 10:05 AM
Red Plate,Tube runaway, glowing screen grids pforeman Tubes / Valves 18 22nd September 2009 01:54 PM
Why does red plate spell early death? Ty_Bower Tubes / Valves 19 28th September 2008 03:37 AM
Is Red Circuit's Guitar controller Really RED? Paswa Chip Amps 7 20th May 2008 04:48 AM
Heathkit W-5M Red Plate Issue Trout Tubes / Valves 7 28th May 2006 02:18 AM
Page generated in 0.59913 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright Đ1999-2013 diyAudio
