Red plate KT88 - Page 4 - diyAudio
Old 13th September 2012, 12:58 AM   #31
20to20 is offline 20to20  United States
20to20's Avatar
Meter lead resistance won't have any impact for a voltage measurement across a sense resistor wired in to the cathode circuit :-)
Ya, the voltage measurement is not where the error starts. It's in determining the resistance value. If you check the resistor and it "reads" 1R, the meter leads are adding anything from .1 -.3 R which means the real resistor value is .7 -.9. My Fluke 77 will read .1 -.2 R in the autoranging mode between leads, on a good day. So .05/.8 = .0625 instead of .05. Whereas .5/9.8 = .051.
Old 13th September 2012, 02:15 AM   #32
trobbins's Avatar
Yes, trying to read a 1 ohm resistor with a typical fluke is asking for question marks on accuracy. Even using a DC supply and a current meter and a voltage meter still needs meters with good resolution and accuracy. I take a backward step and use a new modern commercial resistor, with the view that anything from 1% to 5% tolerance is likely to give me more confidence than trying to make a 'measurement' of the resistors resistance value.
Old 13th September 2012, 12:47 PM   #33
20to20's Avatar
I think having the Fluke read my meter lead resistance is added accuracy. It's just that there is no "0" adjust possible as in many analog meters. I have three sets of meter leads from different quality meters I've purchased and they all have different resistances.
Genalex KT88 Plate Dissipation Question Loren42 Tubes / Valves 7 28th April 2011 10:05 AM
Red Plate,Tube runaway, glowing screen grids pforeman Tubes / Valves 18 22nd September 2009 01:54 PM
Why does red plate spell early death? Ty_Bower Tubes / Valves 19 28th September 2008 03:37 AM
Is Red Circuit's Guitar controller Really RED? Paswa Chip Amps 7 20th May 2008 04:48 AM
Heathkit W-5M Red Plate Issue Trout Tubes / Valves 7 28th May 2006 02:18 AM
Copyright 1999-2017 diyAudio
